Results 1 to 1 of 1
Thread: Cutting down threaded material.
12th Mar 2016, 01:49 AM #1
I've posted this tip before, but I thought I would put it here so that it could easily found.
A quick tip for making short grub screws from threaded bolts or just shortening the bolt. It is one that I often use, that is to screw the donor bolt into a split die and then clamp the die in the three jaw chuck. Then simply part off as required. Transfer the die with the required grubscrew still in it to the vice and then hacksaw a slot in the end. At this point you can use a screwdriver in the slot to clean up the threads by screwing it in or out of the die. Of course you are length limited by how short you can go by the thickness of the die.
I've just cut some M5 countersunk screws down to 8 mm long overall.
See pictures in <//metalworkforums.com/f65/t198825-drill-grinder-4-6-facet>Best Regards:
Material selection, (tooling and cutting speeds).
By glivo in forum METALWORK GENERALReplies: 9Last Post: 8th Jul 2018, 02:19 AM -
Where can I buy Affordable Acme Threaded Lead Screw & Flanged Acme Threaded Nuts
By RoyG in forum METALWORK GENERALReplies: 8Last Post: 1st Sep 2014, 12:26 PM -
ACME Threaded rod
By Lyle in forum METALWORK GENERALReplies: 2Last Post: 2nd Jun 2011, 06:06 PM -
1/2" 13 TPI threaded rod
By snowyskiesau in forum METALWORK GENERALReplies: 5Last Post: 1st May 2009, 09:44 PM
