Results 1 to 4 of 4
    Oct 2004
    Southern Highlands NSW
    1,898
    Default Padsaw blade orientation
    Not a tool I often use, but at times a padsaw is very useful for getting into spaces where a hacksaw won't fit.
    I'm talking about the type of padsaw that takes normal hacksaw blades.
    I used to lament how prone they are to bending or breaking blades, being as they are only supported at one end.
    Then it dawned on me to install the blade so that it cuts on the back-stroke, like a Japanese wood saw.
    No more blade problems.
    It's probably a well known technique, but I've never seen one sold with instructions.
    Nov 2007
    melbourne australia
    3,228
    Brilliant. I’d never thought to do that, and I own two Japanese pull saws!
    I’ve shattered heaps of hacksaw blades using that type of blade holder. Hopefully no more.
    Nov 2017
    Geelong, Australia
    57
    2,665
    Yes, that’s definitely the way to run them.
    Otherwise it’s like playing pool with a rope for a cue
    7,188
    Yep that's How I use mine.
    I have one handle that holds a hacksaw blade cut to a tapered sharp point. I use this to cut out small rectangular switch holes in plastic project boxes. Drill ~6mm hole in inside corners. Then insert the sharp tapered point which easily enables a cut to be started. Sometime I cut holes with a vibratory multi type tool but it tends to partially remelt some of the cut back together. The stapered point which easily cuts through the stuck bits.
  1. What saw blade is this?
    By ptrott in forum METALWORK GENERAL
    Last Post: 1st Jun 2020, 06:17 PM
  2. Patterns-Orientation and runner system suggestions
    By not-a-number in forum THE FOUNDRY
    Last Post: 11th Aug 2019, 05:28 AM
  3. Steel plate orientation when cutting on a bandsaw.
    By Jim Ferrous in forum METALWORK GENERAL
    Last Post: 8th Nov 2013, 08:29 AM
  4. Jig saw blade help
    By lemon2 in forum METALWORK GENERAL
    Last Post: 17th Feb 2012, 04:02 PM
  5. Argon Regulator flowmeter - orientation.
    By obrien43 in forum WELDING
    Last Post: 28th Feb 2010, 07:32 PM
