Results 1 to 4 of 4
Thread: DIY extra length 16mm drill bit
3rd Oct 2018, 04:24 AM #1Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,039
I needed an extra long 16mm drill bit for a one off job recently. I'm sure someone sells them but I couldn't readily find them and they are probably too expensive for a one off. The drill bit I wanted to use is a reduced (1/2" 12.7mm) shank and in crude terms I put a 1/2" hole in the end of a piece of 16mm bright round and used loctite to glue the drill into the extension
The trick of course is to make sure that the extension ends up being concentric and straight with the drill bit, I'm making a 200mm long hole through a block of aluminium.
Holding the 16mm bright round in an ER32 collet in the headstock I first drilled a 12.5mm hole to the required depth. Lacking a proper 1/2" reamer to give me an accurate 1/2" hole I used a 1/2" drill bit as a reamer with surprisingly good results going by the "pop" test - when I pulled the drill out of the extension it made a pop sound which to me means the hole is a good fit. I added some bearing mount Loctite and the extra long drill bit was good to go.
Its a slow drilling/pecking process of course once the flutes are buried in the hole. I was clearing the drill every 10mm, I wanted to stay well away from overpacking the flutes with swarf.
4th Oct 2018, 12:25 AM #2Most Valued Member
Hi Bob, in image 2006, your aluminium block is sitting in a steady, what is the round thing, and how is it attached??
4th Oct 2018, 12:52 AM #3
Hi Kryn,
Its a spider ! Basically a tube with four bolts supporting the work.Best Regards:
5th Oct 2018, 12:10 AM #4Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,039
⅝" (16mm) diameter knurl supplier?
By jack620 in forum METALWORK GENERALReplies: 18Last Post: 27th Sep 2020, 01:19 PM -
Flattening 16mm steel plate for a welding table
By OxxAndBert in forum METALWORK GENERALReplies: 7Last Post: 8th Jan 2018, 07:30 PM -
How To Bend a 6 m Length of 12 or 16mm dia Aluminium Tubing To a 2m Dia Circle?
By mike48 in forum METALWORK GENERALReplies: 8Last Post: 23rd Jun 2017, 09:03 AM -
Best tool for cutting 28mm hole in 16mm Al
By chrisw in forum METALWORK GENERALReplies: 24Last Post: 14th Jan 2011, 09:59 AM
