Results 1 to 2 of 2
    Feb 2013
    Laidley, SE Qld
    1,039
    Default DIY gaskets with accurately positioned bolt holes
    I needed to make a gasket for this wet clutch pressure plate (16 x 5/16" bolts) and tried an idea I recently saw elsewhere. I punched the gasket holes directly through the bolt holes using a quickie home made hole punch. I made the punch (with parallel sides and an internal taper) .1mm smaller than the bolt holes, worked a treat.
    May 2011
    Murray Bridge S Aust.
    5,958
    I've done similar but using a small ball pein hammer. Use the ball end to punch a hole, drop in a bolt of the correct size to locate the gasket, on the opposite side, punch another hole drop in another bolt, then work your way around the perimiter.
  1. More accurately positioned small holes
    By Michael G in forum TIPS, TRICKS & HOW TO'S
    Last Post: 26th Jan 2020, 09:48 PM
  2. Gaskets
    Last Post: 23rd Mar 2015, 07:58 PM
  3. Who can cut mark out and accurately cut with a hacksaw?
    By Grahame Collins in forum METALWORK GENERAL
    Last Post: 22nd Dec 2013, 04:59 PM
  4. Accurately Ground dowels
    By Ueee in forum METALWORK GENERAL
    Last Post: 17th Mar 2013, 10:59 PM
  5. Replies: 24
    Last Post: 11th Dec 2012, 09:40 PM
