Results 1 to 5 of 5
2nd Jun 2019, 08:08 PM #1Member: Blue and white apron brigade
- 7,188
Colour coding stuff to find it quicker.
This one is somewhat trivial but it saves me time every now and then.
Do you have a row or bunch of things that ball look similar but you have pick up and look closely at almost all of them to find the right one?
The red heat shrink tells me they are centre punches as opposed to nail punches or drift punches.
Here's another slightly different case
White heat shrink in my shed means 6mm or 1/4"
Just colour coding one size or two in a selection also you work out which way to go up or down in size
Usually its easy to tell the 1/4" bit as it's shorter than the others
However, in what I'm calling my short set (still building up the set) the length could be anything
Its a pity heat shrink won't go over spanners and then shrink down enough to hold on, I am forever looking for the one to use on a certain thing.
2nd Jun 2019, 08:52 PM #2Most Valued Member
Thanks for those tips Bob
In regard to the spanner for a certain job, could you wrap a bit of coloured electrical tape and then some CA over the join, to keep it there?
2nd Jun 2019, 09:54 PM #3Golden Member
- Vic
- 48
- 544
5th Jun 2019, 10:35 AM #4Most Valued Member
- 4,258
5th Jun 2019, 12:36 PM #5Most Valued Member
- Healesville
- 2,129
Small find amongst FILs stuff
By BobL in forum ANTIQUE AND VINTAGE MACHINERYReplies: 11Last Post: 9th Aug 2019, 02:01 PM -
What colour is your machine? (II)
By Michael G in forum METALWORK GENERALReplies: 16Last Post: 2nd Feb 2015, 10:24 PM -
By Michael G in forum METALWORK GENERALReplies: 11Last Post: 3rd Aug 2013, 04:58 PM -
where did the colour go
By robyn2839 in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 17Last Post: 12th Nov 2007, 06:41 PM -
Colour changes?
By tashammer in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 13Last Post: 5th Jan 2007, 04:40 PM
