Results 1 to 1 of 1
26th Jan 2020, 09:48 PM #1Philomath in training
- 6,542
More accurately positioned small holes
I have a sensitive drilling attachment (SDA) that I bought mainly for my drill press. For those not familiar with them, the smaller chuck is on a spring loaded shaft, so instead of using the quill on the DP, the knurled collar (that has a bearing inside) can be pulled down - much better for 'feel'. The chuck on mine goes up to 1/8", with a 1/2" shaft to go in the driven chuck.
Today I had to drill some 1mm holes and my battery drill chuck would not hold them, so I tried putting in the SDA and used that. Not only did it do the job very well, but by hanging onto the collar, I was able to prevent the drill wandering around as much.
If you have a SDA then here is another use for it, but if you have not, mounting a bearing on a chuck/ shaft similar to this (effectively a SDA without the telescopic spring bit) will at least help get better alignment when starting a small hole, as well as support the weight of the drill a little (smoother feed, less likely to feed too much at once).
boring very small diam holes straight
By tanii51 in forum METALWORK GENERALReplies: 26Last Post: 24th Apr 2020, 10:06 PM -
Ultra Small Holes: EDM vs. Drilling
By joez in forum GENERAL DISCUSSION / OFF TOPICReplies: 0Last Post: 27th Dec 2018, 03:45 PM -
Accurately Ground dowels
By Ueee in forum METALWORK GENERALReplies: 8Last Post: 17th Mar 2013, 10:59 PM -
How To Drill Accurately Located Holes in Inside Radius of Angle Iron?
By abrogard in forum METALWORK GENERALReplies: 24Last Post: 11th Dec 2012, 09:40 PM -
Drilling holes in steel ... small then big?
By Sir Stinkalot in forum METALWORK GENERALReplies: 26Last Post: 4th Mar 2009, 08:33 PM
