Results 1 to 2 of 2
    Feb 2013
    Laidley, SE Qld
    1,038
    Default Setting the height of a slotting saw in the mill
    I'm making a handful of slotted raised head countersunk screws out of stainless M6 hex set screws, for the slotting operation (1mm slot) I'm holding the screws horizontally in an ER32 collet block. I don't have a DRO on my Z axis.
    To set the saw height I turned the end of a piece of M6 booker rod down to 1mm and put the rod in the collet block. From there I was able to eyeball the saw to the same height as the 1mm pimple and I've ended up with screw heads with a centrally located slot.
    Jun 2007
    sydney ( st marys )
    64
    4,887
    Nothing wrong with the method , but that photo makes the whole setup look wrong.
  1. Lathe tool height setting gauge !
    By BaronJ in forum METALWORK GENERAL
    Last Post: 7th Mar 2020, 07:51 PM
  2. For Sale Vic. Bridgeport Mill with Slotting Head.
    By Machtool in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 29th Nov 2016, 09:15 PM
  3. BXY QCTP Height Setting Nut Out-of-square
    By electrosteam in forum METALWORK GENERAL
    Last Post: 24th Mar 2014, 09:13 PM
  4. Setting up a New Mill
    By Oldneweng in forum METALWORK GENERAL
    Last Post: 11th Jun 2013, 10:16 PM
  5. Replies: 23
    Last Post: 28th May 2013, 10:04 AM
