Results 1 to 3 of 3
    May 2011
    Murray Bridge S Aust.
    5,958
    Default MT/Lathe Tooling Rack, Bandsaw Stop, Tool and Cutter attachment
    Found this in an email and thought it was a handy idea.
    https://www.homemadetools.net/forum/...aign=03-27-20&
    A stop for cutting small parts on a bandsaw.
    https://www.homemadetools.net/forum/...391#post155391
    For someone who has run out of ideas to do in the shed LOL, a shop made Tool and Cutter attachment for a grinder. This is part one video.
    https://www.homemadetools.net/forum/...&utm_medium=em
    Apr 2009
    Kingswood
    930
    Default Ballscrew Axial Backlash
    I am investigating the backlash observed in the X-axis movement on my turret mill.
    A DTI on the non-drive end of the screw shows more that 0.1 mm movement when jogged slowly in both directions.
    I think the bearing is a 6207-2ZR.
    Any suggestions on a new bearing selection that would exhibit less axial end-float ?
    Keep well,
    John.
    Aug 2010
    Near Bendigo, Victoria, AUS
    72
    3,104
    Default Not metalwork but CNC: SLA 3D printing
    Hi. I had to/wanted to make some tiny plastic parts with features I could not machine from sold.
    These are gauge knobs for odometers and clocks of 38 year old Honda CX500 turbo motorbikes....
    The two knobs are 10mm diameter and 11mm and 6mm high respectively, with an internal D-shaped hole and 36 triangular shaped knurling on the periphery.
    Thinking of the resolution of my little 3D filament printer made it much too coarse.
    But I've been reading a lot about SLA resin printers lately. So I bit the bullet and bought a small one.
    That's a whole new ballgame! Resolution is down to 10s of microns....
    So I had a go at these knobs at 50micron resolution and here is the results. In the hand they look perfect, but the photos show that the resolution is actually still visible! The difference with SLA printing is that the area printing bears no relationship to the speed. It doesn't care if it prints one pixel or the whole build plate full. Only the number of layers determines the time it takes.
    So I filled it up... 11mm high - 2020 layers which took 1hour...
    This is the printer:
    https://www.ebay.com.au/i/224082610878
    The photos show the printer test (pretty impossible to make any other way), my first 'knob' print job and a close-up of the originals in the foreground with my replicas behind them.
    I'll experiment with tiny parts a bit more in time....
    Joe
    Cheers, Joe
  1. Replies: 9
    Last Post: 20th Apr 2017, 09:01 AM
  2. Tool and cutter attachment.
    By stix012 in forum EBAY, GUMTREE, and other off forum sales sites
    Last Post: 10th May 2016, 09:50 PM
  3. Tool grinding: Form cutter sharpening attachment
    By WoodBee2 in forum METALWORK GENERAL
    Last Post: 28th Jan 2016, 04:55 PM
  4. Tool rack from scrap.
    By AndrewOC in forum THE SMITHY
    Last Post: 18th Jun 2015, 10:34 AM
  5. Cheap'n'cheerful tooling rack
    By toolman49 in forum METALWORK GENERAL
    Last Post: 23rd Feb 2011, 09:50 AM
