Results 1 to 10 of 10
Thread: Garden edge
    May 2019
    Picnic Point, Sydney
    77
    312
    Default Garden edge
    This little tip has nothing to do with metalwork except I'm using aluminium as a base. Admin please delete if inappropriate.
    My landscaper son suggested using pavers as a garden edge for a new project and promised to do the job but he's super busy and can't do it for a while ... but I want it now.
    I thought there had to be easier ways of laying pavers than the traditional concrete footings & cement so why not aluminium channel to sit them in? Luckily I have a friend with the right gear so we cut and folded seven 2400mm aluminium channels. All that's needed now is a 50mm deep channel in the grass for the aluminium to sit. The bends I cut with an angle grinder and riveted to the required angle then it's just a matter of placing the pavers in the channel. Result ... perfectly straight edges and even height tops. Pack the dirt on both sides and it's finished.
    It's not the usual method but it's easy to do and looks professional. The only thing I didn't do and probably should have was to put some drainage holes in the channel. How long the aluminium lasts underground or whether the levels rapidly deteriorate I don't know but for now I love the result.
    May 2011
    Murray Bridge S Aust.
    5,942
    You might start a new trend. Find out if Bunnings will buy them from you?
    6,436
    Hi Snapey,
    A very innovative solution ! I like that Idea and I sure that my wife would too.
    Jun 2011
    gold coast
    303
    Brilliant!!
    Apr 2018
    Drouin Vic
    633
    Get thee to the patent office. That would sell.
    7,182
    Great idea but I'm thinking how an edger blade will go whacking up against the side of the Al channel? Might be a case for whipper snipper only?
    May 2019
    77
    312
    A whipper snipper is all I'll be using so the aluminium doesn't worry me. The channel I made has an edge height of 20mm so with a 50mm paver there's 30mm to play with. If I did produce them that edge height would come down to about 12mm. Is the depth of cut adjustable on an edger?
    Nov 2010
    Gippsland Victoria
    733
    Default Variation on self ejecting taper
    https://www.arceurotrade.co.uk/Catal...th-Release-Nut
    That release nut on the fat end looks like a clever idea - tighten it up and it pulls the taper out of the quill, No more bashing, Could be on all taper tools - wouldn't be difficult to DIY if you ever make any taper tools in future. Saw it discussed on the UK forum.
    Bill
    Aug 2019
    Revesby - Sydney Australia
    56
    1,183
    Quote Originally Posted by steamingbill View Post
    Ausee has them: https://www.ausee.com.au/shop/item.aspx?itemid=4534
    haven't tried one yet
    May 2011
    5,942
    Bill
    Wonder how/if I can modify my DP to do that??? Be interesting to see if the idea becomes standard on drill presses in future, be a good selling point.
  1. Putting a Whirlybird on a Garden shed
    By bwal74 in forum METALWORK GENERAL
    Last Post: 9th Jul 2016, 11:55 PM
  2. Garden shredder/chipper
    By Briangoldcoast in forum GENERAL DISCUSSION / OFF TOPIC
    Last Post: 3rd Oct 2015, 02:06 PM
  3. Spiders in the Garden
    By DSEL74 in forum THE SMITHY
    Last Post: 18th Jun 2015, 12:45 AM
  4. Welding garden art balls.
    By bloodandsawdust in forum WELDING
    Last Post: 26th Mar 2014, 08:16 PM
  5. Garden Arbor
    By yaryetnom in forum METALWORK GENERAL
    Last Post: 17th Oct 2008, 11:35 PM
