Results 1 to 2 of 2
    Aug 2011
    4,779
    Default Cut an internal keyway
    From time to time I have reason to cut an internal keyway.
    Eventually a job for my shaper but it's still in pieces so I do them on the lathe.
    A slow painful process and not particularly good for the lathe.
    However, this time I pre-drilled a hole which removed about 70% of the material.
    So I needed an 8mm Wide x 4mm deep keyway in a 35mm hole.
    On the mill I drilled a 7.6mm hole at 17.5mm out from the centre.
    Then onto the lathe for boring out the 35mm hole and cutting the keyway.
    The pre-drilled hole reduced the time by about 75%.
    Also, the pre-drilled hole acts as a chip breaker so no need for a run-out groove.
    Much easier!
    Sjmon
    6,439
    Much easier!
    Sjmon
    Hi Simon, this picture has the effect of an optical illusion ! When I first looked at it I couldn't understand why there appeared to be a pin in the bottom of the slot, then suddenly it became a drill hole. Weird.
  1. Cutting an internal blind keyway on lathe
    By .RC. in forum METALWORK PROJECTS
    Last Post: 25th Sep 2016, 01:14 PM
  2. Internal Keyway
    By Auskart in forum METALWORK GENERAL
    Last Post: 15th Apr 2016, 09:39 AM
  3. nice video - internal keyway cutting
    Last Post: 9th Oct 2013, 06:45 AM
  4. Suggestions for internal keyway cutting
    By colinshannon in forum METALWORK GENERAL
    Last Post: 23rd Apr 2007, 10:08 PM
