Results 1 to 2 of 2
Thread: RH threads, LH threads
12th Jul 2020, 03:07 AM #1Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,039
I'm making cuphead bolts from 1" round and needed a method of indexing the stock while I milled the square shanks, 1" is too big for the ER32 collets and collet blocks that I have.
I turned the outboard end of the stock to 20mm, attached an ER32 collet block and propped it at the right height for the vice, in this case a piece of 1.25" hex was just right.
26th Jul 2020, 09:14 PM #2Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,039
Whenever I move away for whatever reason from conventional RH single point threading to threading with the tool on the other side of the work, and/or upside down and/or threading away from the headstock I'm never sure which hand thread I'm going to end up with.
From a recent post on PM came this easy to remember method of knowing the answer.
If the spindle and lead screw are turning in the same direction you are cutting a RH thread, if they are turning in opposite directions you are cutting a LH thread.
First threads
By MosquitoGarage in forum THE HERCUS AREAReplies: 11Last Post: 12th Sep 2019, 09:08 PM -
Threads
By Drillit in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 1Last Post: 11th Oct 2012, 03:39 PM -
Missing threads?
By John G in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 1Last Post: 27th Jan 2011, 07:31 PM -
Threads
By benupton in forum METALWORK GENERALReplies: 10Last Post: 2nd Apr 2010, 08:38 AM
