Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
  1. #16
    Mar 2009
    Blue Mountains
    195
    Thanks for that Grahame, will give it a try.
    Mm.
  2. #17
    Jan 2004
    Mackay North Qld
    6,446
    Something that I have just remembered when I go to sharpen a pocket knife .
    Ok! For many of us,we sharpen on a stone on then strop and get a razor edge, ie shave the the hair of the arm.
    You can pick the folks that sharpen lots of knives. Shaved arms.
    To go a step further to prepare an edge that lops of the corner of an A4 printer sheet-try this.
    Try some metal polish.
    Me, I use Autosol Metal polish liquid. I place 10 cent diameter dot of it on the strop and give the blade say, 20 passes or so per side.
    It does not not have to be Autosol. It was just what I had on hand at the time. I am sure similar thick creme like metal polish should have the same effect.
    Perhaps you might try it and let us know your results.
  3. #18
    Nov 2010
    Gippsland Victoria
    733
    Further to Graham's post.
    I've read about people using toothpaste to polish the knifeblade. Google finds lots of examples.
    Bill
  4. #19
    Sep 2011
    Ballarat
    65
    3,103
    Quote Originally Posted by steamingbill View Post
    Bill
    Hi Bill
    That brought back a memory.
    I used toothpaste to lap steam valve and safety valve seats. You could comb your hair in the reflection after you were done...when I had hair that is.
    Phil
  5. #20
    Aug 2011
    4,779
    That show forged in fire is a ripper!
    I have a knife sharpening jig that works on the same principle as that shown in the series but it's smaller and more portable.
    The brand is lansky.
    The various stones you see are different grits ranging from very coarse to ultra fine.
    Here's a pic.
  6. #21
    Oct 2010
    melbourne, laverton
    1,910
    Default Green green green
    Hi mate id never sharpen a knife with a linisher.
    I use the lanski knife sharpener.
    https://lansky.com
    Ive had mine for years .i take it with me when visting family friends and take it when im at sea to sharpen the chefs knifes. It workes great.
    Ive used linishers to make knifes . The belt i go for are green in colour.
    Aaron
    Diy or die.
  7. #22
    Jan 2004
    Mackay North Qld
    6,446
    Quote Originally Posted by azzrock View Post
    https://lansky.com
    Aaron
    Diy or die.
    Aaron
    I am similar to you with a Grandpa Ray sharpener - nearly identical but lacks a base. While it could get the small knives sharp it struggles as the length and width of the larger blades increase. I have used stainless electrodes to increase the length of the sharpening stroke but basically the stones are still too short for the big knives.
    Some of the Ruixin fixed rod sharpening kits can do a wonderful job as well. If they are tweaked to remove the poor tolerances they work pretty well
    The 150 x 20 x 5mm stones are long enough but very poorly fixed to some flexible plastic backing which allows the stones to move and crack.
    Overseas vendors they were asking the equivalent of $70 Au each for decent quality stones. some of the finer stones cut a paper lopping edge (when stropped)
    I"ll trying gluing the plastic to strips of 5mm ali.
    PIC coming.
  8. #23
    Oct 2010
    melbourne, laverton
    1,910
    Default Interesting
    Aaron
    PIC coming.
    Ill have to goggle that one Graham.
    With bigger knifes i just move the jig part.
    Sharpen in two spots. The trouble i have when i try to sharpen thin blades on the 10 or 15 deg slot . I cant get cleareance some times.
    I recantly sharped a mundell carving knife for my brother. A medium size one. He was very impresed . Its held its edge very well . I used the 3rd slot from the blade.
    Ive tried using steels like ghe butchers use h as lf the time i think i blunten the blade.
    I thjnk the the goid thing about the lsnsky is it can be used and stored in tv he kitchen. Not that theres any thing wrong with a linisher in your kitchen.
    I broght a diamond med stone for my set at my local market for $30. A few years ago.
    Aaron
    Diy or die.
  9. #24
    Jan 2004
    Mackay North Qld
    6,446
    Either you are an exceptionally brave fella or you must live alone.
  10. #25
    Oct 2010
    melbourne, laverton
    1,910
    Default your guess
    i actually do have a grinder in the kitchen. its a 10 " polisher under the kitchen table
    waiting for a spot in the shed.
    your right thou currently i have no female cohabiting with me at the moment.
    aaron
  1. What sort of plating would this be?
    By auscab in forum METALWORK GENERAL
    Last Post: 24th May 2018, 11:43 PM
  2. Lathe Knife Tool and Boring Tool Sharpening
    By metaler in forum METALWORK GENERAL
    Last Post: 3rd Mar 2017, 08:38 PM
