Results 1 to 7 of 7
    Mar 2024
    melbourne
    3
    Default Sheraton Defiance thread cutting plate
    Hi,
    I have recently acquired a Sheraton defiance lathe and the plate that says the input for cutting threads is missing, Does anyone have a picture of this plate
    Jun 2007
    sydney ( st marys )
    65
    4,902
    Is the lathe metric or imperial
    Mar 2024
    melbourne
    3
    imperial
    Jun 2007
    sydney ( st marys )
    65
    4,902
    Do a search for your lathe on google, something should come up about Macon/Demco, it will bring up a spec sheet with 48 tpi threads listed, your lathe should have 8 vertical columns and 6 horizontal columns for the thread pitches.
    Start at the lowest tpi, write 8 down, first horizontal column,continue for the next 40 pitches you will end up with 6 horizontal lines and 8 vertical.
    Mar 2024
    melbourne
    3
    I tried that but when I cut a thread to test it was the incorrect pitch, it was about 12TPI when this method and an image of a chart I found for a LeBlond regal (the lathe that this is supposedly a copy of ) said the the thread should be 18TPI.
    Aug 2019
    Revesby - Sydney Australia
    57
    1,211
    See this thread:
    https://metalworkforums.com/f314/t20...raton-defiance
    It is possible that the metric/imperial gear is flipped over? (127/120)
    Nigel, from a cave FULL of unfinished projects and lost tools.
    Jun 2007
    sydney ( st marys )
    65
    4,902
    Your thread pitches should start from right to left, coarse to fine.
    Check for the cub or cadet, I would think it should be the same for the defiance.
  1. Cutting imperial threads on a metric Sheraton Defiance
    By Straydog01 in forum SHERATON AREA
    Last Post: 19th Jan 2024, 08:06 AM
  2. Sheraton 9" AM thread cutting, am I missing a gear?
    By Com_VC in forum SHERATON AREA
    Last Post: 3rd Sep 2023, 09:11 PM
  3. Sheraton Defiance(?) - Heathcote VIC
    By rickw72 in forum EBAY, GUMTREE, and other off forum sales sites
    Last Post: 20th Jun 2019, 10:31 PM
  4. VICTORIA Sheraton Defiance lathe
    By 4-6-4 in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 16th Jun 2011, 11:15 PM
  5. sheraton defiance on ebay
    Last Post: 23rd Nov 2008, 10:13 PM
