Results 1 to 4 of 4
    Sep 2022
    59
    4
    Default Sheraton 9B DRO Specs
    Hi,
    Does anyone have the lengths needed for the DRO sensor sliders to fit a 9" unit?
    The local engineering store has a very nice unit on sale, but you have to nominate the sensor lengths (x2 sensors) and I'm a bit clueless on this front.
    Thanks.
    6,469
    Hi SuperGlide,
    Why not just go and talk to them ! I'm quite sure that they will know what you need by way of measurements.
    Oct 2019
    Adelaide, SA
    1,216
    I will think that the Sheraton 9b will be very similar to a Hercus 9b and so they will probably share the same dro scale lengths.
    Obviously the best way to confirm is to measure the total travel of the slides and take into account the dro reader lengths to choose the appropriate size scales.
    Dec 2013
    56
    1,418
    I have always found the travel advertised lengths with lathes and mills vary slightly.
    I'd measure myself personally.
    Same as scales, they are a bit more than the advertised travel as I found out back in 2007 with my first expensive set and since buying over the years.
    The only type of scale you can be 100% rely on with distance is magnetic as you cut it to length.
    All manufacturers seem to allow 5mm each end, at least.
    Sent from my SM-A235F using Tapatalk
    Using Tapatalk
  1. Strange thread specs
    By nigelpearson in forum METALWORK GENERAL
    Last Post: 26th Feb 2022, 09:02 PM
  2. My Sheraton A
    By Bigcam in forum SHERATON AREA
    Last Post: 7th Dec 2020, 08:32 PM
  3. Help needed identifying this DC motor Specs
    By simonl in forum ELECTRICALS
    Last Post: 7th Dec 2017, 04:26 PM
  4. Hercus 9" Model A Nose thread specs.
    By Nickon in forum THE HERCUS AREA
    Last Post: 15th Jun 2015, 12:00 PM
  5. Sheraton CUB
    Last Post: 14th Dec 2011, 09:31 PM
