Results 16 to 30 of 43
  1. #16
    Oct 2019
    Adelaide, SA
    1,724
    Regardless, if they accept to include it with the lathe then great, else try hard to negotiate a deal because later you will be paying more than you have right now for the lathe to buy them.
  2. #17
    Jul 2008
    near Warragul, Victoria
    3,821
    Default Tafe
    I am surprised that Bairnsdale TAFE would have a lathe that size, it could have been used in the Automotive department maybe. The main training facility for Fitters & Turners in Eastern Victoria was at Yallourn TAFE where they had a large building with many lathes and milling machines and other machining equipment, a heat treating oven , cylindrical grinder and much more.
    I reckon it is a bad deal myself, normally the accessories come with a machine like that. I would be speaking in person to somebody at the TAFE and explain to them that the lathe is next to useless without the accessories. Tell them it is like buying a car , then paying an extra fee for the jack and spare wheel. The office people just need a gentle explanation on how a lathe is set up, you should get a 4 jaw chuck with it at least.
  3. #18
    Feb 2019
    Victoria
    43
    Default GMF CAPTAIN Mark 2 - three phase motor
    I’m loving the little Cadet, despite still being unable to spin anything up on it!
    Our resident sparky tells me that this motor is a dedicated three phase motor and will not take well to bring re-wired to 240 Volts.
    Does anyone have a lead on locating either a 240 v motor or a three phase/high amperage motor with 8” by 6.5” baseplate that also has a 1” diameter shaft?
    cheers
    SJ
  4. #19
    Oct 2019
    Adelaide, SA
    1,724
    You are better off running it off a VFD or a phase converter.
    A 220v motor in the 2hp range rarely comes up on sale in the used market. Or consider buying new.
  5. #20
    Nov 2017
    Geelong, Australia
    58
    2,916
    Just buy one of the 220-380v step up VFDs off AliExpress - usually Ecogoo or Nflixin brand.
    Leave the motor as is, hook up the VFD and configure half a dozen settings and you’re good to go!
  6. #21
    Feb 2019
    Victoria
    43
    Default 2.2 Kw 13.9 Amp 1400 rpm motor
    Gonna slot this motor in once I’ve bored out the pulley
  7. #22
    Feb 2019
    Victoria
    43
    Default Headstock Check
    Shafts and gears look good
  8. #23
    Feb 2019
    Victoria
    43
    Default Motor Base plate
    New motor is just gonna sneak on!
  9. #24
    Feb 2019
    Victoria
    43
    Default SAE 30 Headstock Oil
    Should I be using a BP Autran TO-430 as a dedicated transmission oil for the headstock? Manual & machine says use SAE 30 oil everywhere
  10. #25
    6,945
    Hi Sj,
    SAE 20-40 is a common engine oil ! Straight SAE 30 seems to be in short supply here.
  11. #26
    Feb 2019
    Victoria
    43
    Hi Sj,
    Thanks BJ
    I can get Castrol (Bp by another name) Transmax Off-road 30 locally from the local Trucking Joint. I’ll check with the boss at work before I order it in (and maybe the Castrol tech line) - but I think it might be just the ticket as I suspect it doesn’t contain friction modifiers or extreme pressure additives that could damage brass bushings.
    SJ
  12. #27
    Jul 2008
    3,821
    Default Non-detergent
    Quote Originally Posted by SJ Lambert View Post
    Usually you use a non-detergent oil in headstocks because it allows any metal particles to gravitate down to the floor and stay there.
  13. #28
    Nov 2017
    Geelong, Australia
    58
    2,916
    4 stroke small engine oil is usually straight SAE30.
    Readily available from the likes of the big green shed.
  14. #29
    6,945
    Hi Steve, Guys,
    The local "Motor Save" place does the Two stroke oil in four pint containers at £32 each. At £8 a pint its four times dearer than a pint of beer !!! and it doesn't tell you anywhere I could see what grade it is.
  15. #30
    Feb 2019
    Victoria
    43
    Default New motor mount
    Thanks for all the oil tips folks!
    I’ve progressed the new motor mount packing on the mounting table tonight.
    Still got a bit to do while I’m waiting for a new serpentine belt and will have to see if the boss will let me bore out the old pulley at work on the weekend ( am definitely adhering to the “no foreigners during the week” rule!)
  1. Sheraton Cadet Lathe
    By Stevo1947 in forum SHERATON AREA
    Last Post: 15th Aug 2020, 09:13 AM
  2. WA: 3P 1/2 HP Cadet motor converted for 240V 3P use
    By BobL in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 2nd Feb 2020, 03:43 PM
  3. Brierly Cadet Drill Grinder
    By WoodBee2 in forum METALWORK GENERAL
    Last Post: 3rd Apr 2016, 06:52 AM
  4. Morwell swap meet mart?
    Last Post: 24th Mar 2013, 09:08 PM
