Results 16 to 30 of 43
15th May 2023, 07:12 PM #16
Regardless, if they accept to include it with the lathe then great, else try hard to negotiate a deal because later you will be paying more than you have right now for the lathe to buy them.
15th May 2023, 08:17 PM #17
Tafe
I am surprised that Bairnsdale TAFE would have a lathe that size, it could have been used in the Automotive department maybe. The main training facility for Fitters & Turners in Eastern Victoria was at Yallourn TAFE where they had a large building with many lathes and milling machines and other machining equipment, a heat treating oven , cylindrical grinder and much more.
I reckon it is a bad deal myself, normally the accessories come with a machine like that. I would be speaking in person to somebody at the TAFE and explain to them that the lathe is next to useless without the accessories. Tell them it is like buying a car , then paying an extra fee for the jack and spare wheel. The office people just need a gentle explanation on how a lathe is set up, you should get a 4 jaw chuck with it at least.
20th Jun 2023, 10:27 PM #18
GMF CAPTAIN Mark 2 - three phase motor
I’m loving the little Cadet, despite still being unable to spin anything up on it!
Our resident sparky tells me that this motor is a dedicated three phase motor and will not take well to bring re-wired to 240 Volts.
Does anyone have a lead on locating either a 240 v motor or a three phase/high amperage motor with 8” by 6.5” baseplate that also has a 1” diameter shaft?
cheers
SJ
20th Jun 2023, 10:35 PM #19
You are better off running it off a VFD or a phase converter.
A 220v motor in the 2hp range rarely comes up on sale in the used market. Or consider buying new.
20th Jun 2023, 10:55 PM #20Most Valued Member
- 2,651
Just buy one of the 220-380v step up VFDs off AliExpress - usually Ecogoo or Nflixin brand.
Leave the motor as is, hook up the VFD and configure half a dozen settings and you’re good to go!
24th Jul 2023, 01:55 PM #21
2.2 Kw 13.9 Amp 1400 rpm motor
Gonna slot this motor in once I’ve bored out the pulley
31st Jul 2023, 12:56 AM #22
Headstock Check
Shafts and gears look good
1st Aug 2023, 01:45 PM #23
Motor Base plate
New motor is just gonna sneak on!
3rd Aug 2023, 01:52 PM #24
SAE 30 Headstock Oil
Should I be using a BP Autran TO-430 as a dedicated transmission oil for the headstock? Manual & machine says use SAE 30 oil everywhere
3rd Aug 2023, 04:26 PM #25
Hi Sj,
SAE 20-40 is a common engine oil ! Straight SAE 30 seems to be in short supply here.Best Regards:
3rd Aug 2023, 07:05 PM #26
Thanks BJ
I can get Castrol (Bp by another name) Transmax Off-road 30 locally from the local Trucking Joint. I’ll check with the boss at work before I order it in (and maybe the Castrol tech line) - but I think it might be just the ticket as I suspect it doesn’t contain friction modifiers or extreme pressure additives that could damage brass bushings.
SJ
3rd Aug 2023, 07:47 PM #27
3rd Aug 2023, 08:53 PM #28Most Valued Member
- 2,651
4 stroke small engine oil is usually straight SAE30.
Readily available from the likes of the big green shed.
3rd Aug 2023, 09:59 PM #29
Hi Steve, Guys,
The local "Motor Save" place does the Two stroke oil in four pint containers at £32 each. At £8 a pint its four times dearer than a pint of beer !!! and it doesn't tell you anywhere I could see what grade it is.Best Regards:
3rd Aug 2023, 11:46 PM #30
New motor mount
Thanks for all the oil tips folks!
I’ve progressed the new motor mount packing on the mounting table tonight.
Still got a bit to do while I’m waiting for a new serpentine belt and will have to see if the boss will let me bore out the old pulley at work on the weekend ( am definitely adhering to the “no foreigners during the week” rule!)
Sheraton Cadet Lathe
By Stevo1947 in forum SHERATON AREAReplies: 2Last Post: 15th Aug 2020, 09:13 AM -
WA: 3P 1/2 HP Cadet motor converted for 240V 3P use
By BobL in forum METALWORK - Machinery, Equipment, MARKETReplies: 4Last Post: 2nd Feb 2020, 03:43 PM -
Brierly Cadet Drill Grinder
By WoodBee2 in forum METALWORK GENERALReplies: 0Last Post: 3rd Apr 2016, 06:52 AM -
Morwell swap meet mart?
By neksmerj in forum METALWORK GENERALReplies: 3Last Post: 24th Mar 2013, 09:08 PM
