Results 1 to 8 of 8
Thread: compound removal
4th Jan 2022, 08:28 PM #1Senior Member
- Dec 2020
- Geraldton Western Australia
- 132
compound removal
How do I get the compound off the cross slide on a 9A
4th Jan 2022, 09:27 PM #2Most Valued Member
- 4,890
Remove the handle, undo the graduated ring, a collar should be left behind, it may or may not have a hole on the out side, if it has the hole put a pin spanner in it and release it, if no hole cover the Od of the ring with suitable material, grab it with vice grips, stillsons or multies and turn to release the thread should be right hand,once released screw it out, compound screw will still be retained by the nut, hold the compound and screw the leadscrew out, now release the gib screw if you want and slide the compound off.
4th Jan 2022, 09:46 PM #3Senior Member
- Dec 2020
- 132
Thanks, thought the collar should unscrew but wasn't sure. Handle is off, graduated ring won't clear the locating pin/key for the handle. Wasn't sure if the pin should just pull out. I'll have another go at it.
4th Jan 2022, 09:48 PM #4Intermediate Member
- Apr 2021
- victoria
- 63
- 28
removal of the compound on 9A
are you wanting to take the complete compound rest off the cross slide/saddle - if so you need to loosen the two swivel locking screws (S29 - orange 3/8" square head) located on the back side of the cross slide - see picture with orange arrows pointing to the boltscompund rest swivel lock bolts.jpg
If you want to remove the compound top slide from the base then you will need to loosen the four gib screws (S12 - pink)remove the crank handle by un screwing the handle nut (S16 - green), remove the handle and the graduated collar S14. Loosen the Slide screw bearing (S13 - yellow) might need to wrap a piece of rag around it and use multi grips being careful not to damage it). you can then undo the top slide screw and the top slide should then slide off. This will allow you to get to the Top slide nut (S39) which is held in place with a grub screw (S10A).
Assembly is the reverse, just make sure before you lock the top slide nut in place that you screw the top slide screw back and forth a few times to make sure the nut is in the right place - (not to high or low)
hope that helps
Tony
4th Jan 2022, 10:01 PM #5Senior Member
- Dec 2020
- 132
Can't see the locating pin for the handle in the parts diagram. Guess I could just file a bit off it to allow the collar to clear.
4th Jan 2022, 10:36 PM #6Most Valued Member
- 4,890
Should just pull out, might need pliers or similar.
4th Jan 2022, 11:10 PM #7Senior Member
- Dec 2020
- 132
Nope wasn't going to come out, been in there a long time. Filed a bit off and got it all apart. Should probably drill the rest out and make a new pin.
Thanks Tony for reminding me that I actually have the repair manual in the shed.
4th Jan 2022, 11:17 PM #8Intermediate Member
- Apr 2021
- victoria
- 63
- 28
compound miter saw jig
By eskimo in forum METALWORK - Machinery, Equipment, MARKETReplies: 0Last Post: 29th Mar 2020, 11:50 AM -
ARM compound screw
By m.j.bower.69 in forum THE HERCUS AREAReplies: 44Last Post: 17th Oct 2019, 12:03 PM -
I think i damaged my compound..........
By Zumanity in forum THE HERCUS AREAReplies: 4Last Post: 5th Aug 2019, 05:35 PM -
Replacing the CVA compound
By caskwarrior in forum METALWORK PROJECTSReplies: 7Last Post: 18th Oct 2018, 08:47 PM -
260 BM,CM,B&C Compound Gears
By pipeclay in forum THE HERCUS AREAReplies: 0Last Post: 11th Jan 2010, 06:58 PM
