Results 1 to 8 of 8
    Nov 2021
    Perth, Western Australia
    58
    12
    Default Sheraton A 9" lathe for parts
    Howdy all,
    I have a Sheraton lathe (not complete) - but good for parts that I'd like to give to a Sheraton enthusiast.
    It's in Perth.
    Regards,
    Rhys
    Dec 2020
    Geraldton Western Australia
    132
    Hi Rhys, do you have pictures? What parts are missing / still there etc.
    Regards Cam.
    Nov 2021
    58
    12
    Hi Cam,
    It started as a machine minus a motor and tailstock.
    As there appeared to be not interest - I was hours from throwing it in the skip (so had been stripping it further).
    Essentially there is the Bed, head stock, gearbox, lead screw....and 2/3 of the stand. The saddle assembly, gear cover and sundry parts I've just put in a box.
    What do you need?
    Rhys
    Nov 2021
    58
    12
    Hi Cam,
    Most of the lathe was all there…..minus the tail stock, motor and half the stand. It was hours away from going in the skip – so I stripped what I thought could live on.
    There is now the bed, head stock, gearbox, leadscrew and half the stand. (the bits removed are just in a box)
    What bits do you need?
    Regards,
    Rhys
    Jan 2004
    Mackay North Qld
    6,446
    Hi Rhys,
    Welcome to the MetalWork Forums.
    Thank you for your thoughtfulness in offering the Sheraton spares to those in the forum.
    I am sure members shall reciprocate should you need help in the future.We have quite a few members in Perth.
    To assist you to find your way around the sub forums see below.
    Go to the FORUM box at top LH corner and click on it.
    A drop down menu appears and you can select Forum Home at the top of the drop down menu list. Scan down through the pages to look at what we have.
    Please make sure read the Terms of Use -our Rules - at the top of the scroll down page- pretty standard for many forums these days.By joining the forum its automatic that they apply to you as a member.
    Sometimes the soft ware works so you can't post pics or links until 10 posts are made ( or such links and pics are cleared by a mod)
    Its anti spam thing.
    There's a number of sub forums forum that might be parallel with your interest found as described above.
    You might consider narrowing down the location to the suburb you are in. Its possible to have another member living in the next suburb over and opportunities to borrow a tool or get some help are greatly improved.
    If any questions contact me via PM and I'll try to help you.
    Thanks again for your kind offer.
    Aug 2006
    1,106
    Maybe some photos of what's there would spark some more interest.
    Dec 2020
    132
    It's found a new home.
    Nov 2021
    58
    12
    Thank you for the kind words Grahame,
    As stated by Cam – the Sheraton has moved to its new custodian. (I have a 1968 Hercus 9”AR)
    Interestingly…….at least to me, this Sheraton lathe had the original supplier plate attached to it.
    The Carlyle name actually dates back to 1926 – they merged with Atkin & Co in 1971 to become Atkins Carlyle. Atkins Carlyle were acquired by Blackwoods in 2001.
    Regards,
    Rhys
  1. Looking for Sheraton parts
    By daggagh in forum SHERATON AREA
    Last Post: 5th Nov 2019, 12:26 PM
  2. Wanting to buy a gear cover/guard for a Sheraton 9" Lathe
    By BrazOmatic in forum WANTED TO BUY
    Last Post: 7th Feb 2019, 09:05 PM
  3. Phosphating parts "experiment"
    Last Post: 17th Nov 2014, 10:46 PM
  4. Sheraton 4 1/2" revival.
    By _AL_ in forum THE HERCUS AREA
    Last Post: 7th Feb 2012, 06:40 PM
