Results 1 to 4 of 4
    Jun 2016
    Australia
    2
    Default 9" Model A spare parts wanted
    I am a novice with the lathe but I recently acquired a Sheraton, 9" model A. The aim is to teach myself how to use it. It is in well used condition. The bed does not seem too worn but some of the gearbox gears are showing signs of use. The screw which holds the clutch handle in place is broken. I believe this is a left hand threaded screw. Does anyone know where I can get a replacement?
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Are you referring to the feed selector knob or is there a clutch for the spindle, if it is the knob you are referring to for the feed clutch a Hercus screw may fit.
    Aug 2019
    Revesby - Sydney Australia
    57
    1,196
    Colin, welcome to the forums.
    I have never seen a manual for the Sheraton, but a 9 A is very similar to a Hercus 9 A, or a SouthBend.
    1) You can identify the parts from the Hercus spare parts manual
    https://metalworkforums.com/f189/t156990-pdf-hercus-model-spare-manual/latest/post1931590
    (or attached here)
    2) Mal has many Hercus spares that will fit https://australianmetalworkinghobbyist.com
    3) The Hercus "Textbook of turning"
    https://metalworkforums.com/f189/t10...al#post1978316
    has many helpful tips
    Attached Files Attached Files
    Jun 2016
    Australia
    2
    Thanks for the tip. I have been able to order the bits needed from him.
  1. I have not seen this in the spare parts manuals
    By Tinkerer77 in forum THE HERCUS AREA
    Last Post: 13th Apr 2021, 07:51 PM
  2. PDF of Hercus Model A spare parts manual
    By flmath in forum THE HERCUS AREA
    Last Post: 7th Feb 2019, 01:13 AM
  3. Standard parts for a 9" Model A
    By Mark F in forum THE HERCUS AREA
    Last Post: 13th Mar 2018, 08:02 PM
