Results 1 to 6 of 6
    Apr 2021
    victoria
    63
    28
    Default Sheraton cross slide and compound slide spindle threads
    Does anyone know the correct spec for the cross slide and compound slide spindle threads?
    I need to get a dome nut for my compound slide.
    I measured the thread on the spindle and it was 0.205" and 28 TPI
    This seems to sit in a bit of no mans land with the thread charts I have
    0.2087" - 1BA with 28.2 TPI
    0.2160" - 12G UNF with 28 TPI
    0.2188" - 7/32" BSF with 28 TPI
    The Hercus dome nut is a different pitch - coarse thread compared to the Sheraton, I suspect 7/32 BSW
    Tony
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Do you have lock nuts on your cross slide or compound slide gib screws,if these may be the same as Hercus, which are 7/32"BSF x 28 tpi, you could then take 1 off and try it on your screw to see if it fits.
    Apr 2021
    victoria
    63
    28
    Default Cross slide dome nuts
    Pipeclay, thanks for the reply.
    I have one Sheraton dome nut on the cross slide and this also fits the compound slide.
    I purchased a pair of Hercus dome nuts in the hope they would be the same but they are a much coarser thread, I am advised the Hercus is 7/32" 24TPI BSW. I havent had the opportunity to try them on anything else to confirm this as I dont have any 7/23 BSW bolts etc.
    If all else fails then hopefully our local National Bolts dealer will have some bolts/screws that I can try the nuts on to confirm their size etc.
    thanks again, Tony
    Apr 2021
    victoria
    63
    28
    Default spindle nuts
    and I forgot to say the gib screws on the Sheraton have no lock nuts on my lathe - just a grub screw, but I will check the size and fit with the Hercus dome nuts I have as well as the Sheraton dome nut as you mentioned.
    thanks
    Tony
    Aug 2006
    1,106
    Is it worth fitting lock nuts on the gib screws? Do they tend to move around over time?
    Apr 2021
    victoria
    63
    28
    Default Gib Screw lock nuts
    Com-VC
    thanks for the tip re the screws moving around a bit.
    the gib screw heads are virtually flush with both the rests so Id have to get longer screws and lock nuts. The screws should be easy enough to get and I will then have to turn down the tips a bit to fit the gib strips.
    cheers & thanks again
    TonyB
    Quote Originally Posted by Com_VC View Post
  1. Sheraton Defiance cross slide removal
    By Straydog01 in forum SHERATON AREA
    Last Post: 5th Apr 2021, 01:36 PM
  2. Myford ML7 cross slide and compound screws
    By dadrock in forum METALWORK GENERAL
    Last Post: 14th Apr 2018, 11:48 AM
  3. 260 Compound and Cross Slide Micrometer stud thread???
    By ventureoverland in forum THE HERCUS AREA
    Last Post: 25th Nov 2014, 03:41 PM
  4. Cross slide spindle with dials? cost?
    By xXvapourXx in forum THE HERCUS AREA
    Last Post: 9th Jan 2013, 12:12 PM
  5. sheraton A cross slide nut
    By danielhobby in forum THE HERCUS AREA
    Last Post: 21st Apr 2011, 07:50 PM
