Results 1 to 6 of 6
Thread: motor noise
12th Jun 2021, 08:56 PM #1Senior Member
- Dec 2020
- Geraldton Western Australia
- 132
motor noise
I found the cause of faint scraping noise coming from my lathe motor, the remains of a mummified mouse,some Ratsak and the nest!
I also discovered why it tripped the RCD, corroded earth wire poked into one of the phase wires.
Probably not too bad considering the wiring hasn't been looked at since the 1960s.
12th Jun 2021, 11:41 PM #2Most Valued Member
- 2,672
I reckon that mouse was trying to tell you something…..
13th Jun 2021, 12:51 AM #3Senior Member
- Dec 2020
- 132
Time for a little TLC, cleaned it all, repacked bearings, new heatshrink and tomorrow I'll replace the wiring between the switchgear and the motor.
Runs very well considering it's age.
13th Jun 2021, 04:50 PM #4
One of the original "Brooks Motors" made in Huddersfield UK !
I've not seen a "Cub" in maybe 50 years or more ! A good solid motor, very heavy for its power output.
The graphic at the bottom left on the first page is actually an image of the original pre=war Empress works. They later took over some derelict property on the same street in order to expand the works. Mainly warehousing I believe. Then they added some new production faculties in "Doncaster" which doubled the production ability.Best Regards:
13th Jun 2021, 04:57 PM #5Senior Member
- Dec 2020
- 132
I also have one on my Servian drill press.
13th Jun 2021, 05:03 PM #6Senior Member
- Dec 2020
- 132
Not sure that I'd like to be near it if it had the Hi-Low pulley running at top speed!
Noise Reduction
By Satwinder Singh in forum METALWORK GENERALReplies: 25Last Post: 17th May 2020, 10:27 PM -
Motor Noise
By Anorak Bob in forum ELECTRICALSReplies: 5Last Post: 31st Oct 2017, 09:58 PM -
Bearing noise
By ratters in forum THE HERCUS AREAReplies: 10Last Post: 13th Feb 2015, 08:19 PM -
my noise maker
By eskimo in forum GUNSMITHINGReplies: 34Last Post: 21st Apr 2014, 11:15 AM -
Noise from MH 48 mill
By Ben Dono in forum METALWORK GENERALReplies: 33Last Post: 11th Feb 2012, 05:50 PM
