Results 1 to 3 of 3
Thread: Sheraton C Rebuild
10th Sep 2020, 10:11 PM #1Member
- May 2018
- Cairns, Qld.
- 70
Sheraton C Rebuild
The saddle/main carriage is now finished. No real dramas. The only real fault was the saddle lock that could never have operated fully & correctly as the component parts were locking up against a lump in the front face casting; easily remedied. Dismantle, clean, remove surface rust & poor paint & check all the parts. Minimal wear overall. Minor rectifications as necessary, paint & re-assemble.
Was... Is now - back on the bed...
Attachment 388606
Next job; the chuck as it was....
Chuck @ 50%.jpg Stiff to operate & looks a bit rough externally.
Attachment 388609
And after a strip & clean-up...
Attachment 388607Attachment 388608 Actually found in very good condition once all the gunk was cleaned out, minor corrosion removed & the scroll & jaws were freed enough to move. Now operates smoothly. Jaw grip faces appear to be good. It is a 'TOS' brand of 125mm dia. Is that a Czech company?
Now moving on to the tailstock.... It appears to have been shot off the end of the bed & bounced on the floor at some time in its history. (Wobbly shaft & cracked hand-wheel plus the eye bolt or cross-shaft inside appears damaged). Not unusual I think, when there is no end-stop on the lathe bed to prevent that happening. I'll have to find a way to prevent that re-occuring.
Attachment 388610 Work in progress currently...
Thanks to Baron J for pointing out that the pictures went awol initially.Last edited by Halifax614; 11th Sep 2020 at 10:01 PM. Reason: Pictures needed reloading
11th Sep 2020, 06:08 AM #2
Halifax, you need to reload your pictures !
23rd Sep 2020, 11:06 AM #3Senior Member
- Oct 2019
- Tasmania
- 53
- 150
I just found this thread and I have to say wow you have really brought that old girl back to life.
I love restoring old equipment like this, well done for your efforts so far.
Keep the pictures coming.
Sheraton C Rebuild
By Halifax614 in forum SHERATON AREAReplies: 1Last Post: 30th Aug 2020, 03:41 PM -
Sheraton C rebuild
By Halifax614 in forum SHERATON AREAReplies: 0Last Post: 9th Aug 2020, 07:20 PM -
Hercus +rebuild with DRO
By NickMortimer in forum THE HERCUS AREAReplies: 8Last Post: 17th Jun 2016, 09:14 AM -
Trailer rebuild
By artme in forum TRAILERS & OTHER FABRICATED STUFFReplies: 3Last Post: 29th Jan 2012, 11:15 PM -
9" rebuild
By 12bolts in forum THE HERCUS AREAReplies: 2Last Post: 20th Jan 2012, 07:38 AM
