Results 1 to 8 of 8
    Apr 2020
    Ettalong Beach NSW
    62
    72
    Default Clutch assembly help please.
    In the process of slowly going through the different parts of the Sheraton.
    I removed the plate behind the clutch assembly and I saw the two half shells and half disks. One of the disks appeared like it had fallen out of the slot. (Excuse my ignorance of the correct names).
    Once cleaned, I attempted to re-assemble. I just can't get the half disks to fit in the slots at the same time as getting them in the shells. After trying for about an hour, I figured I'd ask here and see if I can have a face palm moment. Any advice please?
    This pic is from the net, a Hercus that looks like it is supposed to, and the other pics are of my apron.
    May 2011
    Murray Bridge S Aust.
    5,959
    Vic, was there any grease or similar in that/those parts?
    Wondering if a SMALL dob of grease in the "slots" would help hold them in place.
    If you can't have grease there, would a couple of small magnets hold the half against the shell, with the shell not all the way in?
    Apr 2020
    Ettalong Beach NSW
    62
    72
    There was no grease anywhere.
    The issue with getting the disks in, is that about about 1mm of the outside edge of the disks run up against the outer edge of the shells.
    They fit in fine when off the spindle, but the slots in the spindle make them expand out too much.
    6,477
    Hi Vic,
    Not easy to see, but is there a spring on the shaft at the back ? And does the shaft move backwards and
    forwards ?
    I think that is a spring and spring pressure holds those retaining plates in place.
    Apr 2020
    Ettalong Beach NSW
    62
    72
    Yes, I've had the shaft out. The spring is there. It's not so much the retaining of the disks, but working out how to fit them in. I get that the slots in the shaft hold them in place. It just seems that the outside edge of the disk is about half a mm wider then the shell when trying to get them to fit in the slot of the shaft as well.
    The disks fit in the shell without the shaft, but the shaft makes the disks push outward just that little bit.
    Feb 2014
    Werribee, Melbourne
    178
    I can't speak from experience but are the photos / description of this Hercus rebuild of any use?
    hercus page 5
    Apr 2020
    Ettalong Beach NSW
    62
    72
    Ah! The disks go in at an angle! Thank you, that rebuild link will make all the difference. 😁
    Apr 2020
    Ettalong Beach NSW
    62
    72
    Did it in 1 minute flat
  1. How to make a dog clutch
    By TommyGMachining in forum Members Videos
    Last Post: 20th Oct 2019, 09:06 PM
  2. Zinc key box assembly
    By mun9 in forum METALWORK GENERAL
    Last Post: 1st Aug 2016, 10:24 PM
  3. Single revolution clutch- pin clutch or similar unit
    By nswnotill in forum METALWORK GENERAL
    Last Post: 20th Dec 2015, 07:22 PM
  4. A clutch for the Douglas Shaper
    By Steamwhisperer in forum METALWORK GENERAL
    Last Post: 27th Mar 2013, 02:22 PM
  5. Tacking and job assembly for beginners
    Last Post: 24th Feb 2008, 03:55 PM
