Results 1 to 5 of 5
Thread: Cross slide play adjustment? 9C
3rd May 2020, 09:56 AM #1Novice
- Apr 2020
- Melbourne Aust
- 21
Hi guys,
I seem to have a bit of play in the feed on the cross slide,
It moves back and forth about 1/4 of a turn b4 engaging.
This isn't a huge problem for me when I am turning as I'm a beginner and don't know any better lol
But when I use a milling attachment it allows the stock to shudder badly.
Is there a way of adjusting the play in the cross slide? or do I have to replace the cross feed screw and nut?
Any Advice is appreciated
3rd May 2020, 10:24 AM #2Diamond Member
- Aug 2019
- Revesby - Sydney Australia
- 1,195
Replacing parts is the best fix, but here are some crazy ideas (hacks?):
- Thick grease in the feed screw & nut.
- Clamp the cross slide in position.
(depending on what sort of milling operation you are doing.
You might need to turn the job around) - Put a large spring on the slide.
(say, clamp on the back of the slide, pulling toward the bed,
or in the front, pushing away from the feed handle)
3rd May 2020, 04:36 PM #3
wear
its a very common problem, most older lathes have some wear in the cross feed screw and nut, its usually a bronze nut . The screw wears away at the centre section where its used the most. Replacing the nut only fixes half of the problem. You can buy a length of new cross screw and fit it into the handle , its a ACME thread form from memory . In some cases it is possible to make a new nut from a modern synthetic material, its been written up on various web sites , you use a heat gun and melt the material onto the screw for a perfect fit.
3rd May 2020, 10:37 PM #4
Another method
Another method https://www.practicalmachinist.com/v...ssfeed-189062/
5th May 2020, 08:48 AM #5Novice
- Apr 2020
- Melbourne Aust
- 21
AL960 top slide adjustment & threading
By eskimo in forum METALWORK GENERALReplies: 74Last Post: 2nd Sep 2016, 02:44 PM -
Cross-slide play
By jack620 in forum METALWORK GENERALReplies: 23Last Post: 19th May 2012, 07:50 AM -
Cross Slide Nut
By raypat in forum METALWORK GENERALReplies: 19Last Post: 9th Dec 2011, 01:41 AM -
Hercus 260 Cross-slide play
By jack620 in forum THE HERCUS AREAReplies: 19Last Post: 26th Sep 2011, 08:47 PM -
sheraton A cross slide nut
By danielhobby in forum THE HERCUS AREAReplies: 5Last Post: 21st Apr 2011, 07:50 PM
