Results 1 to 6 of 6
Thread: My Sheraton introduction
16th Apr 2020, 08:42 AM #1Novice
- Apr 2020
- Melbourne Aust
- 21
G'day everyone,
I was gifted this Sheraton a year or so ago and spoke to Mal re replacement parts etc, I needed some gears, 54/18 and a 72/18 compound gear,idler gear bolt, a tailstock, oilers and felts etc.
Well after a long while a hercus came up so i thought I would buy that and use the parts to make one functioning unit.
Turns out the main part I needed, the tailstock doesn't line up, so I'm still on the hunt for a Sheraton tailstock.
Oh and of course I have decided I now want to refurbish both units lol
The other parts I can get from Mal when Im ready unless someone has bits they want to sell on just let me know
I have attached some pics of the machine as it sits, prior to me starting any rebuild works
48364757_10217140081869722_184516858802601984_o.jpg48429542_10217140082629741_1401530335006556160_o.jpg49558638_1991449064309352_6305755097179619328_n.jpg72416476_555189158356289_5089806004065927168_n.jpg
16th Apr 2020, 10:45 PM #2
gears
The Sheraton uses a different PA angle on the back gear teeth than a Hercus does. I found out as I fitted a Hercus back gear on my Sheraton and a holy loud noise resulted
17th Apr 2020, 06:49 AM #3Novice
- Apr 2020
- Melbourne Aust
- 21
20th Apr 2020, 08:52 AM #4Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,894
20th Apr 2020, 10:12 AM #5Novice
- Apr 2020
- Melbourne Aust
- 21
7th May 2020, 01:38 PM #6Member
- Sep 2016
- Canberra
- 87
There are two parts to the tailstock unit we need to consider here. The body and the base. Nadroj is correct, there is cross adjustment on the tailstock base. In what way does it not fit? Height or cross? Cross will be easier to correct, height is a little trickier. Shims, Turcite, scraping etc.
Depending on how much its out you may need to make a new base for the tailstock to get it aligned on the Sheraton. This is not hugely difficult but it does take time and you will need to be patient and careful in order to get it right.
FWIW I would purchase another Hercus tailstock for the Sheraton and do the above mentioned and keep that Hercus complete! That's a roller bearing 9c and is a fine machine. Assuming its in good condition it would be well worth keeping.
From my own experience I can tell you it's extremely useful and convenient having two lathes if you have the room.
Best regards
Matthew
Sheraton SG
By KBs PensNmore in forum METALWORK GENERALReplies: 17Last Post: 14th Aug 2018, 09:44 PM -
An introduction to my Grinding Rests
By metaler in forum METALWORK GENERALReplies: 1Last Post: 21st Feb 2017, 09:37 PM -
Sheraton CUB
By morrisman in forum METALWORK GENERALReplies: 0Last Post: 14th Dec 2011, 09:31 PM -
Introduction
By matthew_g in forum METALWORK GENERALReplies: 1Last Post: 6th Aug 2008, 10:03 PM -
INtroduction
By barkersegg in forum METALWORK GENERALReplies: 9Last Post: 25th Jul 2007, 09:41 PM
