Results 1 to 7 of 7
Thread: Sheraton conquest inquiry
3rd Nov 2019, 08:53 AM #1New Member
- Nov 2019
- Australia
- 47
- 6
Good morning all
I am looking for the wiring diagram for the conquest.
The motor on this as you all would be aware has two sets of windings.
The majority of the starter panel is missing including contactors .
I have found the uk site but before buying a book just for the wiring diagram thought I would see if someone could help out.
Nick
3rd Nov 2019, 04:00 PM #2Senior Member
- Nov 2010
- Frankston south
- 102
whilst I don't have the wiring diagram, I think I have some pictures of the original layout of mine. I replaced the motor with a single speed motor and VFD.
I'll dig them out after I finish watching the Sepang Motogp.
3rd Nov 2019, 04:05 PM #3New Member
- Nov 2019
- Australia
- 47
- 6
Thank you
3rd Nov 2019, 09:28 PM #4Senior Member
- Nov 2010
- Frankston south
- 102
Your thanks where a little premature...
I've searched all the sd cards and folders of information I have without success, i'm sorry to say. I'll keep looking and if they turn up you'll hear about it.
3rd Nov 2019, 09:37 PM #5New Member
- Nov 2019
- Australia
- 47
- 6
No problems at all I do appreciate the effort.
Speaking to friend whom i purchased the lathe from he said he has a frequency drive I can use if need be.
As long as the lathe can reach its speed of 2500 rpm ill be happy .
Im not sure if its rated to beyond that in the bearings and lubrication setup as I havnt turned up anything in my research of anyone else doing this to theirs.
3rd Nov 2019, 09:43 PM #6Senior Member
- Nov 2010
- Frankston south
- 102
The motor I have put on is rated the same rpm, I use a vector drive VFD and it supplies ample grunt at low speeds
3rd Nov 2019, 09:45 PM #7Senior Member
- Nov 2010
- Frankston south
- 102
As an addendum.....the only time I've let the lathe sing at those speeds is to polish
Sheraton SG
By KBs PensNmore in forum METALWORK GENERALReplies: 17Last Post: 14th Aug 2018, 09:44 PM -
Sheraton Conquest Head Gear
By Quoll15 in forum METALWORK GENERALReplies: 9Last Post: 7th Dec 2012, 10:04 AM -
Need Sheraton Conquest info
By xXvapourXx in forum METALWORK GENERALReplies: 14Last Post: 25th Jul 2012, 12:37 AM -
Sheraton CUB
By morrisman in forum METALWORK GENERALReplies: 0Last Post: 14th Dec 2011, 09:31 PM -
sheraton conquest lathe
By leopardwood in forum METALWORK GENERALReplies: 11Last Post: 7th Jun 2010, 08:59 PM
