Results 1 to 4 of 4
    May 2009
    Hobart, Tasmania
    21
    Lightbulb Belt grinder build (on a budget)
    Hi Folks,
    If you like machining and fabricating you might enjoy my latest build video - my rendition of Jeremy Schmidt's 2x72 belt grinder build:
    https://youtu.be/mRlDBfHnCko
    Craig
    May 2011
    Murray Bridge S Aust.
    5,959
    Thanks Craig, great video. What size motor did you use?
    May 2009
    Hobart, Tasmania
    21
    Hi Kryn,
    Thanks for the compliment!
    It's an old GMC motor that I bought from a friend a while back. 1hp, 1440rpm, single phase. I don't know for sure how old it is - but it's quite old. It does says 1962 on the tag, but I don't know if that's motor age, or the age of the BS spec it applies to. It was always intended as a temporary motor, because it was what I had on hand at the time.
    I do have my eyes open for a good value 2hp 3-phase motor, that I can drive from a VFD to get higher and lower speeds for a range of materials. It shouldn't be too difficult to do the upgrade if I find something suitable.
    Craig
    Jun 2005
    Helensburgh
    618
    Quote Originally Posted by craigmarshall View Post
    Hi Folks,
    Craig
    And coincidentally about the same colour we sprayed the two machines we built. A great video, your presentation is excellent. Have you made any of the accessories Jeremy made?
    CHRIS
  1. Belt Grinder
    By eskimo in forum METALWORK PROJECTS
    Last Post: 26th May 2019, 08:45 PM
  2. Belt grinder build.
    By onanonanon in forum METALWORK GENERAL
    Last Post: 4th Jun 2018, 12:48 PM
  3. Twin belt belt grinder.
    Last Post: 18th May 2018, 03:52 PM
  4. Belt grinder/linisher
    By China in forum METALWORK GENERAL
    Last Post: 2nd Jan 2018, 10:33 AM
  5. belts for belt grinder
    Last Post: 20th Jun 2016, 09:23 AM
