Results 1 to 1 of 1
4th Jul 2022, 01:53 PM #1
Repair a drum mower blade disc drive gear
My neighbour has a drum mower with two broken blade disc drive gears.
The shaft holding the rotating blade plate had a fatigue crack that ended up breaking the shaft into two pieces.
I do a simple repair for this component by tapping a M14/1 thread to the gear and then making a stud bolt to replace the broken off part.
In this video I am using:
- Weiler Matador SV (1972) Lathe
- Schaublin SV-51 (1955) Milling machine
fancy mower repair.
By azzrock in forum METALWORK GENERALReplies: 15Last Post: 10th Jun 2020, 10:34 PM -
Newbi needs to repair crack in old mower base.. tips ?
By Widget83 in forum WELDINGReplies: 16Last Post: 1st Mar 2017, 10:39 AM -
Override Brakes - Drum to Disc?
By RustyArc in forum TRAILERS & OTHER FABRICATED STUFFReplies: 6Last Post: 6th Aug 2016, 12:55 PM -
repair saw blade weld?
By glenn k in forum WELDINGReplies: 4Last Post: 6th Oct 2009, 06:12 PM
