Results 1 to 14 of 14
    Oct 2021
    Finland
    66
    86
    Default Making a rotary vane compressor
    This is the first episode of a video series of making a rotary vane compressor.
    In this video I am using:
    - Weiler Matador SV (1972) Lathe
    - Schaublin SV-51 (1955) Milling machine
    - Solberga (1975) Drill press
    The video
    Oct 2021
    Finland
    66
    86
    Thanks for moving the Video to here.
    I did not notice earlier that there was this compartment for videos.
    So now I know
    Oct 2021
    Finland
    66
    86
    Default Making another part for the rotating vane compressor.
    This part includes a precision hole for the bearing bushing.
    I fail with shrink fitting the bearing bushing but succeed in rescuing it.
    - Wohlhaupter UPA3 Boring/Facing head
    - Tapmatic 50X Tapping head
    [The video is here[/URL][/B][/SIZE]
    Aug 2010
    Near Bendigo, Victoria, AUS
    72
    3,105
    Hi! And welcome to the forum.
    I'm watching your videos with great interest - as a long-time suscriber.
    Something interesting every video.
    Keep it going, please.
    Cheers, Joe
    Oct 2021
    Finland
    66
    86
    Default Making a fairly complex part for the rotary vane air compressor.
    This part has three precision recesses which will be done using the Wohlhaupter UPA3 boring/planing head.
    - Wohlhaupter UPA3 Boring/plaining head
    - Tapmatic 50X reversible tapping head
    The video is here
    Oct 2021
    Finland
    66
    86
    Default Making gear pump gears for lubrication system
    Since the vanes of this compressor will be made out of steel, some lubrication is needed.
    There will be a gear oil pump that forces the oil into the blades and also pushes the vanes against the cylinder walls hydraulically.
    Two identical precision gears are therefore made.
    - BS0 Dividing head
    Join the channel:
    I upload new videos every other week, usually more frequently.
    If You want to see more of my videos, click LIKE & SUBSCRIBE!
    The video is here
    Oct 2021
    Finland
    66
    86
    Default Testing the oil pump.
    There are quite some silly animations. Enjoy!
    The video is here
    Oct 2021
    Finland
    66
    86
    Default The Cylinder
    The cylinder of this air compressor must be quite accurate.
    I am using my Bison 250mm 4-jaw chuck to turn this cylinder.
    There is a lot of metal removal and problems associated with it.
    Drilling and tapping holes to the ends of the cylinder.
    It is a rather simple task but having them in a perfect bolt circles that are aligned between the ends is no more a simple task.
    Tapping 16 blind holes to 20 millimetre deep M4, that is not a trip in the park either.
    In these videos I am using:
    - BS0 Dividing head
    - Tapmatic X50 tapping attachment
    First part is here
    Second part is here
    Oct 2021
    Finland
    66
    86
    Default The rotor
    This time it is the rotor.
    It is made out of 50 millimetre cold rolled steel.
    There will be precision turning and eliminating the taper.
    The video is hiding here
    Oct 2021
    Finland
    66
    86
    Default How to make six grooves 3 millimetres wide and 15 millimetres deep?
    You could try to make those with an endmill but since the grooves are 100 millimetres long that would be a major PITA to pull through.
    The obvious answer is, of course, the humble slitting saw.
    Traditionally I have had no luck whatsoever with those and usually I end up collecting slitting saw shrapnel from my floor.
    It will be very exiting to see what is the outcome this time.
    Oct 2021
    Finland
    66
    86
    Default This time it will be the lamelles for the compressor.
    There are 6 of them and they are made out of Uddeholm Vanadis 4 tool steel.
    This steel is quite tough to machine and there are also some challenges with setups.
    I will also get a stopping reminder why safety goggles are a must.
    The video is here
    Oct 2021
    Finland
    66
    86
    Default This time it will be another steel puck for the compressor.
    There will be a precision recess for a shaft seal.
    I will be using my Wohlhaupter UPA3 boring head to make that one.
    - Wohlhaupter UPA3 Boring head
    Join the channel:
    You can also subscribe here
    The video is here
    Oct 2021
    Finland
    66
    86
    Default Will this compressor become silent?
    Air enters and exits the compressor through holes in the cylinder walls.
    I machine flats on cylinder sides and holes for air flow.
    Then I put the thing temporarily together and test it.
    The video is hiding behind this link
    Oct 2021
    Finland
    66
    86
    Default The output manifold is just a block of steel with three holes and a recess.
    Although it is so simple, I manage to make a major mistake with it.
    I am lucky enough to catch the mistake in time and take corrective actions.
    The video is here
  1. Making a rotary welding positioner
    By Tilly819 in forum Members Videos
    Last Post: 17th Nov 2020, 05:11 PM
  2. Air compressor's
    By gazza2009au in forum GENERAL DISCUSSION / OFF TOPIC
    Last Post: 13th Aug 2018, 01:28 PM
  3. Making a CNC rotary table
    Last Post: 3rd Mar 2017, 11:15 AM
  4. Making A Compressor?
    Last Post: 4th Jan 2017, 10:24 PM
