Results 1 to 5 of 5
    Apr 2019
    Finland
    46
    117
    Default Very simple angle grinder cutting guide
    This is a very simple angle grinder cutting guide for 125mm ( 5" ) angle grinder.
    Its made in first place, to help cutting pipes, welded mesh or rebars on hard to reach places.
    But it helps in many other ways too.
    Video shows some of the uses and contains measures and shows steps,
    how-to-make your own guide to standard type & size 125mm angle grinder.
    https://www.youtube.com/watch?v=1Nipltkf2O0
    Supplies:
    125mm angle grinder, with guard.
    Welder
    3mm thick steel plate. Piece 150mm x 50mm ( 6" x 2" )
    Cut off wheel
    Flap disc
    Marker
    Scribe
    Hammer
    Try square
    Tape measure
    Vise
    Pair of clamps or locking pliers
    Jan 2004
    Mackay North Qld
    6,446
    Good one! Tuomas.
    It will be so very handy and dispense with any guesstimation on my part.
    Apr 2019
    Finland
    46
    117
    Good one! Tuomas.
    Thank you Grahame.
    I have done manu cuts with it now. Just clamp liner or try square to the plate and cut.
    In my my grinder, distance from the wheel to the the edge of guide, is 24mm.
    When i need 100mm wide cuts, i place guide to distance of 125mm when using 1mm wheels.
    Feels almost too simple and lame.
    It would have been funnier to make something more complicated with moving parts and adjustments. ��
    Dec 2005
    South Australia
    1,656
    Great Idea, I wonder how it will be before we see this a an accessory
    Apr 2019
    Finland
    46
    117
    Quote Originally Posted by China View Post
    Thank you.
    This could be easily "stamped" to the guard in manufacturing process... Never know if Wish, Aliexpress or stores like that solds it one day.
  1. Circle cutting guide
    By Tuomas Soikkeli in forum METALWORK PROJECTS
    Last Post: 3rd May 2019, 07:17 PM
  2. Angle grinder cutting baseplate
    Last Post: 28th Jun 2017, 10:23 PM
  3. Cutting simple curves on a vertical mill
    By Andrew C in forum METALWORK GENERAL
    Last Post: 1st Mar 2013, 02:37 PM
  4. Replies: 27
    Last Post: 20th Oct 2008, 09:04 PM
  5. Quick Screw-Cutting Guide
    By Article99 in forum METALWORK GENERAL
    Last Post: 25th Jul 2007, 11:14 PM
