Results 1 to 2 of 2
17th Sep 2019, 02:21 PM #1New Member
- Sep 2019
- Longford tasmania
- 75
- 1
Adapter from Hafco AL336 toolpost to QA-140 quick change too post
I have a fairly new Hafco AL336 lathe with a standard square toolpost and have purchased a QA-140 quick change toolpost. Does anyone have a sketch for an adapter between the two?.
17th Sep 2019, 10:18 PM #2Most Valued Member
- 4,887
If your current tool post uses a tee slot in your compound the new one should just need the tee nut that should come with it machined to suit the compound slot , machining can all be done on the lathe,you may also need to face the stud to length.
Dickson quick change toolpost
By china eyes in forum METALWORK - Machinery, Equipment, MARKETReplies: 4Last Post: 11th Jan 2019, 05:59 AM -
Quick Change Toolpost Which Is Better
By steran50 in forum METALWORK GENERALReplies: 90Last Post: 23rd May 2017, 11:49 AM -
AXA quick change toolpost on AL960B
By B the B in forum METALWORK GENERALReplies: 18Last Post: 13th May 2011, 01:50 PM -
By nexusone in forum METALWORK GENERALReplies: 3Last Post: 2nd Jan 2008, 07:52 AM -
Quick change toolpost -make your own
By forge in forum METALWORK GENERALReplies: 3Last Post: 18th Sep 2006, 07:12 PM
