Results 1 to 2 of 2
    Sep 2006
    South Coast of New South Wales Australia
    296
    Default Work Shop Talk - 3 in 1 shear brake roller mod
    Easy mod to make it much more simple to cut squarely.
    Cheers Jim
    My Youtube Channel -
    Blue Heeler's Model & Toy Steam Engine Room
    Sep 2006
    296
    For making brass/copper boxes its just superb. The shear is effortless (I didn't show it in the video, but there is a spring loaded lock down device that automatically holds down what is being sheared) and the brake folds metal perfectly. The brake and shear are easy to use and operate.
    Now the roller. The roller can be frustrating as its all done by feel. There's nothing to dial in so to speak and it takes a bit of guessing and fiddling around to get just right. Before I try rolling expensive plate like copper/brass I practice on sheet metal that I get from the local tip from the sides of washing machines and other white goods that have thin steel etc there's a limitless supply.
    The more you use the roller the more you start to learn how it works and for me there was a learning curve.
    Cheers Jim
  1. Shop made metal roller?
    By saxguy in forum METALWORK GENERAL
    Last Post: 11th Feb 2018, 02:12 PM
  2. Job Shop work via Youtube
    By YBAF in forum METALWORK GENERAL
    Last Post: 31st Mar 2016, 12:18 PM
  3. Book Machine Shop Work
    Last Post: 22nd Nov 2015, 09:30 AM
  4. A Slip roller - work in Progress
    By jhovel in forum METALWORK PROJECTS
    Last Post: 9th Nov 2015, 08:04 AM
  5. work shop vac
    By azzrock in forum METALWORK GENERAL
    Last Post: 20th Aug 2011, 11:42 AM
