Results 1 to 2 of 2
    Apr 2019
    Finland
    46
    117
    Default Homemade random orbital sander attachment
    Made a random orbital sander attachment with 8mm movement, to be used with drill, angle- or bench grinder.
    https://www.youtube.com/watch?v=A4bI...ature=youtu.be
    Note, that centrifugal force that makes backing to spin, also increases its spinning speed higher than the actual speed of the used motor.
    I used backings made to be used with 13.ooo rpm speed, and 2000 rpm with my angle grinder, which has a variable speed.
    My bench grinder runs 2200 rpm.
    Works nicely, and gives smoother result than my bosch sander which has only 2.5mm movement.
    I made it to be used with bench grinder. I can use whole are for sanding, and use my both hands for holding the object.
    But in hand held too.
    It doesn't leave disturbing scratches, finished surface is much better than with the traditional disc sander.
    Somewhat easy to make, cheap, small.
    Balancing takes some time.I used two days filing it to the right size and weight, but i think it was worth it.
    Apr 2019
    Finland
    46
    117
    Here is the finished random orbital bench sander
  1. Any thoughts on Air vs. Electric Orbital Sander ????
    By ventureoverland in forum METALWORK GENERAL
    Last Post: 13th Jan 2021, 11:18 AM
  2. - Two in one belt sander angle grinder attachment -
    By Tuomas Soikkeli in forum METALWORK PROJECTS
    Last Post: 23rd Apr 2019, 07:33 PM
  3. Orbital sander
    By Michael G in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 1st Apr 2019, 08:58 AM
  4. Home made belt sander attachment.
    By KBs PensNmore in forum METALWORK GENERAL
    Last Post: 6th Jun 2018, 09:29 PM
  5. Hitachi Random Orbital Sander service
    By Ropetangler in forum METALWORK GENERAL
    Last Post: 12th Sep 2012, 01:03 AM
