Results 1 to 13 of 13
9th Feb 2024, 01:12 PM #1Senior Member
- Dec 2012
- emerald
- 161
Indicator light for submersible pump operation
Hi guys,
Just wondering if anyone knows of a plug in device that could go between a 240 volt outlet and a 3 pin plug that would activate an indicator light when the float switch on the submersible pump is on? Ie. when there is current flow.
I'd just like to get an idea of cycle times, but have no way of knowing when it's running and when it's off. I'd imagine there would have to something available. Thanks.
9th Feb 2024, 01:44 PM #2I break stuff...
- Aug 2010
- Toorloo Arm, VIC
- 40
- 1,385
If you've got wifi at the location, this:
https://www.bunnings.com.au/arlec-wh...meter_p0273367
Otherwise this style will work if you want to stand and watch it:
https://www.jaycar.com.au/mains-power-meter/p/MS6115
I doubt you'll find an off the shelf plug in indicator light as you describe, that's a pretty specific use case, and most situations requiring that will have a hardwired control panel for same. But, anything is possible...
9th Feb 2024, 06:24 PM #3Senior Member
- Dec 2012
- emerald
- 161
Thanks for that. Yes, this one from Jaycar might be the next best thing.
I had a situation a while ago when the float switch got hooked up and the pump kept running 24 / 7 and I didn't know it. Obviously it buggered the pump, so I thought something like this might alert me to anything like this in the future.
Thanks again.
9th Feb 2024, 06:48 PM #4Most Valued Member
- 58
- 2,830
Years ago there used to be electronic kit sets that would plug in between the 240v outlet and the load (ie pump in your scenario)
When there was current flowing to the load it would turn on a secondary power outlet on the device.
Great for plugging a sander and vacuum into - hit go on the sander and the vacuum automatically gets power and then turns off when you stop the sander.
In your pump scenario you could plug an indicator light into the current switched outlet.
Can’t see any online currently from a Quick Look though.
My shop vac has the function inbuilt.
You plug your sander into the outlet, set the power switch to the “controlled” position and when you start the sander the vac turns on.
Steve.
9th Feb 2024, 06:56 PM #5I break stuff...
- Aug 2010
- Toorloo Arm, VIC
- 40
- 1,385
They do still exist, I just managed to dig this one up after you reminded me of their existence:
https://www.timbecon.com.au/ivac-dus...ox-anz-version
Looks like it'd be much cheaper if you can use one of those WiFi units though! Other advantage of the WiFi unit is it apparently can be configured to give you a history of runtimes etc, so you don't have to watch a light with a stopwatch.
9th Feb 2024, 08:15 PM #6
I have no particular experience with this pump situation however I will say that the Arlec/Orion Grid connect offerings are slightly dumbed out for ease of use based on my experience with their home automation stuff and I am still running a few of their security solutions.
Without going into specifics, but 1. everything seems limited to the smartphone app 2. There are limited functions supported by their trigger/automation setup.
For example from a home security perspective, I want to be able to arm/disarm the entire motion sensing aspect of security system based on geo-location of my phone or by a single click. No it can’t do that. I have to launch the app, go into each device (cameras, motion sensors, contact sensors) and turn off motion detection. Annoying as those functions are not exposed through the app for triggers/automation.
Basically all I am saying is that it’s a closed system that is not very adaptable.
Edit: I forgot to mention that some Arlec devices do not connect directly to the WiFi and require a smart hub (aka Zigbee devices m). So ensure you are getting the correct type of device that connects through the Wifi (aka Tuya WIFI) without the need for a smart hub.
Sorry for side tracking this discussion.
10th Feb 2024, 09:00 AM #7Senior Member
- Dec 2012
- emerald
- 161
10th Feb 2024, 05:44 PM #8
Plenty of cheaper versions but unsure of current stockists. Just search for "master slave powerboard"
https://www.doss.com.au/doss2016/product/33540300/
https://www.amazon.com.au/SPB5ECO-DO.../dp/B077M432H1
https://www.bournesuperstore.com.au/...wer-board-with
https://www.wagneronline.com.au/nla-...927/974155/pd/
19th Feb 2024, 10:16 AM #9Member
- Apr 2020
- Hackham West
- 55
- 55
Hi, i am curious...what is the application of this pump?
19th Feb 2024, 05:48 PM #10
28th Feb 2024, 06:15 PM #11Senior Member
- Dec 2012
- emerald
- 161
28th Feb 2024, 09:24 PM #12Member
- Apr 2020
- Hackham West
- 55
- 55
No worries...thanks. Have you sorted this?
1st Mar 2024, 12:47 PM #13Senior Member
- Dec 2012
- emerald
- 161
Washing machine pump as a coolant pump
By BobL in forum METALWORK GENERALReplies: 66Last Post: 9th Oct 2015, 09:25 PM -
Replacement submersible oil pump for EDM sinker
By johntopp in forum METALWORK GENERALReplies: 18Last Post: 13th Aug 2013, 01:52 PM -
Air Tool Operation
By Oldneweng in forum METALWORK GENERALReplies: 14Last Post: 5th Aug 2013, 08:33 PM -
Slitting Saw Operation
By electrosteam in forum METALWORK GENERALReplies: 16Last Post: 12th Jan 2010, 10:23 AM
