Results 61 to 75 of 75
Thread: 3hp 120L Air Compressor
26th May 2024, 05:07 PM #61Most Valued Member
- Aug 2009
- Sydney, NSW, Australia
- 2,308
Ok just checked it the tank is building around 10psi of pressure as when i unscrewed the check valve off the tank a big gush of air came out but i would estimate it 10-12psi
I firstly took the small hose off the check valve and ran the compressor with my finder over the hole and it built pressure
So disassembled the check valve and it looked ok, could the check valve some how create more pressure on the rubber seal over time?
I don't know wether to replace the switch or check valve or both
The air is bleeding from the nylon hose connection at the switch but its actually bleeding from the port hole when once the compressor builds pressure to 145psi it opens the valve to release the hose pressure
Pictures are not working on this site guys i'll upload one here
https://ibb.co/pRSFKn2
26th May 2024, 05:49 PM #62
Within the switch should be the un-loader valve, when the compressor is running the full pressure is in the tube running to the switch. When the tank reaches pressure the un-loader valve will release any pressure in the system between the compressor and the on way check valve.
The check valve stops pressure in the tank being released.
So your answer is depends on when it is leaking, during the time the compressor is running or once the tank has reached pressure and the compressor has switched off.
26th May 2024, 06:26 PM #63Most Valued Member
- Aug 2009
- 2,308
Air leak's from the unloader valve about 3 seconds after i turn the compressor on with a empty tank
26th May 2024, 08:53 PM #64
26th May 2024, 09:15 PM #65Most Valued Member
- Aug 2009
- 2,308
I left the compressor for 2 hours and came back than released the air in the tank she steadily held around 10psi enough for a huge woosh out the drain valve, before i root around ordering a new switch from ebay i will need to measure mine to make sure i get the same unloader hose diameter fitting
I will buy a plug to plug up the unloader at the check valve to make sure i can build atlease 100psi and shut the pump off, need to inflate the flat boat trailer tyres
28th May 2024, 06:08 PM #66Most Valued Member
- Aug 2009
- 2,308
Finally got it working i used a blank on the unloader valve port on check valve it had a tiny leak from the blank, she managed 50psi in 10mins 120 litre tank so i will set the cut off at 125psi kick on at 90psi, i will make a final post after i have the new switch installed with 0 to 125psi and i'll time it from 90psi to 125psi to calculate my CFM, previous CFM was 17cfm but the spec's were 11-12cfm
2nd Jul 2024, 12:59 AM #67Most Valued Member
- Aug 2009
- 2,308
Trying to finish off this air compressor my one way valve is faulty, tried looking everywhere for a 3/4" 1/2" 1/8" one way check valve with a female bleeder i can't find one this big anywhere
I tried looking for a rebuild kit but my rubber is 18mm which there are none this size on ebay although the ebay repair kit's don't give exactly where the rubber is measured i just measured the diameter
How else can i fix this?
2nd Jul 2024, 05:37 PM #68
You sure its 1/8 ?
They like to make life hard and have imperial and metric on the same fitting
https://www.ebay.com.au/itm/31524035...Bk9SR57QpKKOZA
2nd Jul 2024, 06:32 PM #69Most Valued Member
- Aug 2009
- 2,308
The thread's look square but the bloke at Pertek sold me a 1/8" BSPT i had asked for a 1/8" BSP, anyway that was just a block off to test the pressure build up
Just checking the thread now a M10x1.5 tap is way to course for the thread all i have that fit's in the hole is the 1/8"BSPT blank and a 1/8 NPT tap that also fit's the hole but both bind at 6mm depth
2nd Jul 2024, 06:43 PM #70
2nd Jul 2024, 08:25 PM #71Most Valued Member
- Aug 2009
- 2,308
Measured the male side it's roughly 9.47mm thread diameter and pretty difficult to work out my thread tool it just has number's on one side and 1.25,.8 etc on the other side so i just checked and the thread pitch was "28" so i'm assuming that's 28 TPI
so it look's like the male bolt is 9.47mm diameter and a 28 TPI
i will try look up all the info now, I'm not great with imperial can never work out there 1/8" to .40 or whatever can never work it out
2nd Jul 2024, 08:39 PM #72Most Valued Member
- 70
- 1,582
1/8" BSP is 28TPI.
Nev.
2nd Jul 2024, 11:16 PM #73Most Valued Member
- Aug 2009
- 2,308
Thank's guy's should have it sorted now i will order the check valve droog posted and use a female 1/8" BSP to male M10 fitting for the bleeder
9th Jul 2024, 05:26 PM #74Most Valued Member
- Aug 2009
- 2,308
New one way valve showed up and its fittings are much smaller so i went to pertek and the guy just said we don't have anything that will fit, i said u have 80 fittings on the wall nothing will fit.. he just did'nt want to help
So now all i can do is try sand the old seal
22nd Jul 2024, 02:26 PM #75Most Valued Member
- Aug 2009
- 2,308
Finally guy's the air compressor is up and running with no leak's i only actually took it up to 50psi as i only needed to pump up two boat trailer tyres and my electric bike tyre, i am in the process of releasing the excess air from the tank i cracked the drain valve only slightly sound's as loud as a sicada as not to of neighbours but it's been releasing air for over 20mins now anyway i can build a muffler im worried the neighbours will complain, i have tried adjusting the release valve and it's as quiet as i can get it can clearly hear it inside my house
VIC Air compressor 40 L
By Turbine Builder in forum METALWORK - Machinery, Equipment, MARKETReplies: 0Last Post: 31st Dec 2023, 11:25 AM -
SA Air compressor
By snapatap in forum METALWORK - Machinery, Equipment, MARKETReplies: 1Last Post: 1st May 2022, 09:12 PM -
What oil for air compressor?
By Com_VC in forum METALWORK GENERALReplies: 25Last Post: 14th Aug 2018, 09:20 PM -
May need another compressor... How big.. Used or New??
By ventureoverland in forum METALWORK GENERALReplies: 25Last Post: 25th Jan 2015, 09:21 PM -
air compressor
By mirage1 in forum METALWORK GENERALReplies: 3Last Post: 13th Jul 2006, 11:47 PM
