Page 4 of 5 FirstFirst 12345 LastLast
Results 46 to 60 of 66
  1. #46
    Aug 2009
    Sydney, NSW, Australia
    1,923
    Droog the flaired copper hose is sealing, the 1/2BSP threads are leaking i tried tightening it it's very tight so i need thread tape or a thread sealant as the top of the thread is bubbling..
  2. #47
    Sep 2005
    Bendigo
    60
    446
    You appear to have a 1/2 compression fitting with a 1/4 BSP threaded barb screwed into it.
    If the 1/2 BSP thread is leaking it is because the flare is not sealing, the threads are not designed to seal!
    On the other hand if it is the 1/4 BSP threads that are leaking then yes use thread tape or other thread sealant.
    The adaptor that you have to accept the barb fitting, is it a compression flange on the other end or is it just a 1/4 BSP female to 1/2 BSP male threaded adaptor ?
  3. #48
    Nov 2008
    North Brisbane. Qld. Australia
    70
    1,538
    You may have to cut the copper pipe and fit a new compression fitting.
    Nev.
  4. #49
    Aug 2009
    1,923
    Yeah you are right Droog appoligies, the flared copper pipe is leaking i have done it yup super tight with 2x large shifter's
    I may just cut the copper hose, i bought the wrong yellow/blue hose too i thought the main center oump pipe was the output which was 8mm so i brought 8mm hose but the other pipe it's connected to now is the output which is 10mm
    So i will go buy a fitting for 10mm to 14mm and some new hose and cut the brass fitting off that's leaking
    I just could'nt workout how the thread is leaking but the bottom of the fitting isn't leaking
  5. #50
    Aug 2009
    1,923
    I just annealed the copper hose and got it to seal, i have gone over every connection with soapy water except in the switch for obvious reason's, i have gotten under the tank and sprayed the drain fittings and i just can't find a leak
    30mins of running the pump than i release the drain valve and the very tinnest his of pressure
    Do i need to remove this section from the pump? It looks like it could be a one way valve or a trap of some sort but i know nothing about fridge/air con compressors
  6. #51
    Sep 2005
    Bendigo
    60
    446
    As per post 8
    Back to the air compressor found a lengthy video on youtube of a homemade fridge compressor air compressor, the comment's suggest the 3x pump's with the 200L tank take's 20min's to fill at 8bar 115psi
    What did the YouTuber do for the configuration in his setup, did you use the same compressor ?
  7. #52
    Aug 2009
    1,923
    Quote Originally Posted by droog View Post
    As per post 8
    No from memory that homemade model used 3x fridge compressors, i'm uzing a air conditioner compressor
    Here's the 200L 3x pump diy air compressor
    https://youtu.be/vQQY0kgXuPE?si=Ansj1zudjvgAXdKb
  8. #53
    Aug 2009
    1,923
    My pump is likely a goner guy's bugger, instead of air being sucked into the vent tube its blowing out i have also swapped the hoses on the pump and again it does the same thing, i will check it one last time tomorrow by swapping the hose again
    I may need to find another pump they are everywhere on facebook so quiet easy to find
  9. #54
    Sep 2005
    Bendigo
    60
    446
    Have you confirmed which port is the suction and which is the discharge ?
    Make and model will help find some info but yours sort of looks like this.
    https://www.pinterest.com.au/pin/coo...1435755275809/
  10. #55
    Aug 2009
    1,923
    Looking at videos of verticle compressor pump's the top port is the discharge, the port on the side cylinder looking thing is the intake
    But i have connected the tank to both sides, i will go check now
  11. #56
    Aug 2009
    1,923
    I just disconnected the hose and there's next to no pressure from either port on the pump
  12. #57
    Aug 2009
    1,923
    Got it sorted i had the run and start wires reversed on the capacitor, had live going to the start side of the capacitor when it should have been to run
    I will reconnect the hose tomorrow and get her working
  13. #58
    Aug 2009
    1,923
    Pump works awesome now and gee she pumps out a lot of air much more than i estimated this tank should not take long to fill but i now have a leak
    The part circled which triggers the on/off switch is leaking really bad, it's leaking right where it meets the aluminium part
    The hose isn't leaking i have removed that and trimmed the end and reconnected
  14. #59
    Sep 2005
    Bendigo
    60
    446
    Looks like you are missing a photo ??
  15. #60
    Aug 2009
    1,923
    Tried to upload a pic but would'nt upload, i searched youtube and it said my check valve is faulty or dirty so i will pull it apart shortly
  1. VIC Air compressor 40 L
    By Turbine Builder in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 31st Dec 2023, 11:25 AM
  2. SA Air compressor
    By snapatap in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 1st May 2022, 09:12 PM
  3. What oil for air compressor?
    By Com_VC in forum METALWORK GENERAL
    Last Post: 14th Aug 2018, 09:20 PM
  4. May need another compressor... How big.. Used or New??
    By ventureoverland in forum METALWORK GENERAL
    Last Post: 25th Jan 2015, 09:21 PM
  5. air compressor
    By mirage1 in forum METALWORK GENERAL
    Last Post: 13th Jul 2006, 11:47 PM
