Results 1 to 9 of 9
    Aug 2019
    Revesby - Sydney Australia
    57
    1,196
    Default Dead winch, motor reversal issue
    Customer has a fairly new winch. Something like this:
    which has been working OK for a month, but suddenly stopped working in one direction.
    Can drop it down, but not lift up!!!
    No problem, thinks I, broken switch?
    Go there today, momentary DPDT switch seems OK. Look into circuit:
    there is a dual capacitor. 15uF and 40uF.
    I've never actually played around with reversing single phase motors.
    I'm guessing one cap value drives it forward, and one is sufficiently out of phase to drive it backward?
    I test the cap(s?) with a little LCR:
    and they seem OK.
    Then I try something. Swap the cap wires on the switch.
    I thought this would cause the "up" position to go down.
    It didn't. The up position gave a slight motor hum for a microsecond, then nothing.
    And the down position still went down.
    Very confused!!!!!
    6,480
    Hi Nigel,
    A bad connection to the cap can still give you a good capacitor reading on those digital meters ! Whilst to get a capacitance reading and what seems like a good esr, there is not enough current in the circuit to be sure that the capacitor is good under operating conditions.
    Anyway reversing a single phase motor is not difficult. Simply reversing the start coil connections will do that. Which is what the lower switch does. I would check that the switch actually works !
    Nov 2016
    Gulfview Heights, Adelaide
    83
    There may be a faulty limit switch or adjustment somewhere in the lifting mechanism.
    If you have a in line current meter, check the current in both directions.
    It is unlikely to be the capacitor given that it works ok in one direction.
    Paul
    Apr 2018
    168
    Quote Originally Posted by paul33 View Post
    Paul
    Those cheap hoists have a ring arrangement and a disc clamped around the cable which activates a limit switch to stop the up operation.
    Probable a issue with adjustment of the limit switch or faulty switch. For their price they are a handy hoist. We used a few where I previously
    worked to move motors and Vac pumps from and to mezzanine platforms. Had a few instances of the up limits failing.
    Sep 2006
    Australind , WA
    58
    1,281
    How many wires going to the motor itself?
    If its 3 , it might be similar to a lathe I worked on once. It had a centre tapped winding. Centre tapping was neutral and one end was Active for Forward, the other end was Active for reverse.
    It used the same configuration switch that a 3 phase motor would use.....effectively reversing 2 phases.
    Aug 2019
    57
    1,196
    Quote Originally Posted by Sterob View Post
    Unknown. Four from the handset up, but I didn't have a 3m high ladder to investigate the other end.
    Tomorrow morning's problem
    Aug 2010
    Near Bendigo, Victoria, AUS
    72
    3,105
    Almost guarantee a molten switch. Possibly the change-over switch on the pendant. They are awfully wimpy for the starting current of those motors. Or the limit switch as mentioned already. Same crappy quality....
    Cheers, Joe
    Aug 2019
    57
    1,196
    Took the tall ladder, and investigated.
    Paul and Sparksy were correct. The limit switch was somehow jamming.
    The cable goes to a pulley, and its support was somehow twisting:
    I twisted the pulley around a little, attached an extra brace:
    and instructed the owner to check the limit switch (cable guiding loop) is free, if the fault ever happens again.
    Apr 2018
    168
    Hope they dont use it for much load, way that pulley is setup guiding the cable to end of the drum it will bunch up on that end and put strain on the cable. Should have been 2 pulleys used, first one a bit lower to drum and central and the other in similar position to existing. Could do away with the limit switch as it wont work anyway.
  1. winch motor
    By shedhappens in forum ELECTRICALS
    Last Post: 8th Mar 2021, 09:40 PM
  2. Unimac DC motor controller issue.
    By lamestllama in forum ELECTRICALS
    Last Post: 11th Sep 2020, 06:03 AM
  3. Electric drive motor issue
    By ratters in forum THE HERCUS AREA
    Last Post: 29th Aug 2016, 12:55 PM
  4. Winch post angle
    By mbaldwin in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 6th Aug 2016, 11:57 AM
  5. Motor Issue
    By Stustoys in forum METALWORK GENERAL
    Last Post: 29th Dec 2013, 10:14 AM
