Results 1 to 7 of 7
Thread: Single phase motor that got wet
12th Nov 2022, 05:30 PM #1Most Valued Member
- 2,651
The small single phase pump we use for the garden has got a big wet in all the rain recently. I went to use it and it was tripping the RCD in the switchboard.
Getting about 0.3M ohms when tested with the megger, and has definitely had water inside.
What are my chances of it coming right once it’s dried out?
12th Nov 2022, 05:53 PM #2Diamond Member
- Aug 2019
- Revesby - Sydney Australia
- 56
- 1,183
70% chance of coming good?
(just a guess)
I imagine the electrical leakage was in the terminal box.
The windings themselves still look to be well insulated.
Carefully scrape some of the salt out, blow the salt/water/dirt out, sit it in the sun, and re-test!
12th Nov 2022, 06:05 PM #3Golden Member
- May 2020
- Willowbank QLD
- 517
It looks to have a lot of dirt build up. I would give it a good wash with clean water. If you have access to an oven I would bake on very low heat for a few hours, if not sun dry. There is a high chance it will work. Bearings may need lubrication or replacement.
12th Nov 2022, 07:08 PM #4
Was it meggered with all the terminals attached or on the bare leads on the windings as pictured ?
Dirt and moisture on the uninsulated terminals is often an issue but if it was on the bare leads it indicates that the insulation on the windings may be compromised.
You could varnish the windings after they are clean and dry.
12th Nov 2022, 07:20 PM #5Most Valued Member
- 2,651
Thanks guys. Sounds like it’s probably worth persevering with.
I did the initial megger test with the terminals still on, but it’s the same when tested with just the bare windings.
12th Nov 2022, 07:27 PM #6
3rd Dec 2022, 06:36 PM #7Most Valued Member
- 2,651
Just to tidy up the thread - I dried it out for a few days and it was much better - about 30M ohm with a 500v megger test.
It then sat in the shed until today when I reassembled it and performed a smoke test.
It passed and is now back in service
Thanks all…
Single phase to three phase motor replacement - Motor Size?
By Halifax614 in forum ELECTRICALSReplies: 6Last Post: 12th Nov 2021, 07:01 PM -
3 Phase Generator Motor Powered by Single Phase Motor?
By gazza2009au in forum ELECTRICALSReplies: 49Last Post: 4th Apr 2020, 04:38 PM -
Single phase Vs 3 phase motor ratings.
By KBs PensNmore in forum ELECTRICALSReplies: 56Last Post: 17th Sep 2017, 05:37 AM -
Replacing A Single Phase Motor With A Three Phase Motor....................
By matthew_g in forum METALWORK GENERALReplies: 26Last Post: 1st May 2015, 04:42 PM -
Looking to swap a 2Hp single phase motor for 1.5 or 2Hp 3-phase motor
By jhovel in forum METALWORK GENERALReplies: 7Last Post: 10th Mar 2014, 07:26 PM
