Results 1 to 5 of 5
13th Aug 2022, 10:26 PM #1
Electrical Maintenance Technician wanted
I have a Ruhla universal milling machine.
Built in the late 70s or early 80s.
At this time I'm having problems with the spindle motor being slow to start and cutting out.
I suspect the spindle motor is not getting all 3 phases.
I need to find a electrical maintenance technician in the Perth metro area, who can test the relays, motor and transformer.
Plus order replace or fix faulty componates.
I'm hoping someone on this forum can make a recommendation.
Thank you MarkI've become a tool of my tools.
14th Aug 2022, 12:06 AM #2
Hello Mark,
Before you go any further I would check all the fuses, make sure that they are at least finger tight and not loose ! Those bottle fuses have a habit of becoming loose.Best Regards:
14th Aug 2022, 10:00 AM #3Most Valued Member
- 4,258
if it was mine: I would start from beginning.
Those old US style fuses will be hard to get if you need a replacement.
The overload down in the bottom right with orange button is a ring in and appears to be hanging in mid air as I believe it is was fitted as a stop gap measure as an original original could be found (this in fact makes the board illegal ((hanging in midair)) in the eyes of the authority) ...but hey...if it works and gets one out of trouble for a short time then why not?? but not for ever!
Most of those contactors/relays are so old I doubt the is enough silver left on the contacts....and I dont refer to the possibility that the silver has worn off due to use over the years but rather they are so old our atmosphere has eroded the silver from the contacts.
I need a trip to Perth..fly me over and I will fix for free ...parts at your expense.
Seriously tho I would make a new board.
you need a sparky with control experience...not your average domestic household sparky...ask the question to the sparky..do you know electro/mechanical control wiring.
14th Aug 2022, 12:51 PM #4
I renewed all of the fuses when I first got it they are not the problem because the mill runs.
I have been running the mill for about a year now.
Diagnosis was complicated by a damaged motor speed selector switch inside the spindle gearbox selector box.
Getting a replacement was not a option so I ran the wires to a control panel and replaced it with manually activated rotary switch, when I sorted mechanical problems inside the selector box.
A interlock switch on the gearbox selection locking bar can be a pain too because their is no external indication that it has been activated.
I intend to add a pilot light to the interlock.
I have made enquires at a local machining shop to see if they can recommend a technician, I'm waiting for the boss to get back to me.
So I'm exploring all avenues to find the right person.
That overload thing that Eskimo pointed out is offset a little to one side its not a problem
I know the machine going to be expensive to fix but what isn't.
14th Aug 2022, 01:07 PM #5Most Valued Member
It might be OK. They come with solid bars that insert into the terminals of the contactor. Whether that is considered solid enough under the regs I don’t know.
https://www.tro.com.au/7-10A-Thermal...SABEgIaZvD_BwEChris
Maintenance on the Anayak
By shedhappens in forum METALWORK PROJECTSReplies: 22Last Post: 22nd Jul 2020, 08:52 PM -
VFD Maintenance
By BobL in forum ELECTRICALSReplies: 5Last Post: 20th Oct 2017, 11:23 PM -
Bridgeport 2J Maintenance
By Bennett in forum METALWORK GENERALReplies: 8Last Post: 31st Jul 2013, 05:01 PM -
Inverter Maintenance
By citybook in forum WELDINGReplies: 7Last Post: 2nd Feb 2012, 02:19 PM -
myford s7 maintenance
By arkade31% in forum METALWORK GENERALReplies: 10Last Post: 24th Oct 2007, 01:51 PM
