Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
  1. #16
    Jul 2006
    Athelstone, SA 5076
    4,258
    I would just use a bolt on crimp lug...maybe solder the wire to the lug....like these
    After all the lug you have shown uses a screw.
  2. #17
    Aug 2009
    Sydney, NSW, Australia
    1,844
    Since not being able to find the original's I'm going the place each terminal in a vice and drill out the cables than bend the crimp tab's out with a nail or plyers
    I'll than heat each terminal with the propane torch and recoat it with solder than recrimp it onto new cables
    Very time consuming job but its all i can do
    Aftermarket lugs may not fit as some terminals are bent 90 degrees
  3. #18
    7,189
    I'd be going with the eskimo lugs too.
  4. #19
    Nov 2008
    North Brisbane. Qld. Australia
    70
    1,513
    Use cable lugs. Nothing else you have considered will be adequate. Cable lugs can easily be bent to 90 degrees. I would not solder. A proper crimp and some shrink tube will be much better.
    Nev.
  5. #20
    Aug 2009
    1,844
    Eskimo's lugs need a 3mm hole for the screw's, i measured the cable last night they are 4mm2 so there will be lugs out there in this size cable i just have to search for 4mm2 and 3mm holes if i were to go that way
  6. #21
    Nov 2008
    70
    1,513
    Not sure yet and no promises, but I have a stash of small cable lugs some of which may be the correct size, so I'll have a look tonight or tomorrow. If I do, maybe I can send you some.
    Nev.
  7. #22
    Nov 2008
    70
    1,513
    The lugs I have are much like the CG2.5M4 H1436A at this link -
    https://www.gvk.com.au/pdf/utiliux.pdf
    They are actually thicker for the 1.1mm C dimension at 1.7mm. ID of wire section is close to 4mm diameter. Hole diameter is 4mm. All other dimensions are close to what is stated on the chart. Overall they are quite a bit heavier duty than you normal spade (blade?) connector. Not sure if there's an amperage rating available for these. If you want a few I could probably spare a dozen, so PM me your details and I'll slip them into an envelope for you. If you are in a hurry I am sure they would be available local to you.
    Nev.
  8. #23
    Nov 2008
    70
    1,513
    Just found 6-4 stamped on the lug which I am sure is suitable for 6mmSq cable and has a 4mm diameter mounting hole.
    Nev.
  9. #24
    Aug 2009
    1,844
    Thanks Surf i'll pick some up this week from a electrical supplies store, thinking of filling in the holes with solder and redrilling and threading to the screws i have
  1. 240V Light Extension/Connectors
    By bwal74 in forum ELECTRICALS
    Last Post: 12th Aug 2021, 10:49 PM
  2. High Speed No.O ???
    By Anorak Bob in forum THE HERCUS AREA
    Last Post: 8th Jun 2019, 10:19 PM
  3. Carbide Spade Drill Bits
    By Chris Parks in forum METALWORK GENERAL
    Last Post: 14th May 2017, 10:36 PM
