Page 2 of 2 FirstFirst 12
Results 16 to 24 of 24
  1. #16
    Apr 2018
    163
    Quote Originally Posted by Sterob View Post
    Apologises Sparksie.....I think I have 'oopsed'
    Yes, its a BLDC motor. I read 'star' and thought '3 phase motor'.
    I might be sunk.....
    https://www.monolithicpower.com/en/b...shed-dc-motors
    Look like a fisher paycal washing machine motor.
  2. #17
    Sep 2006
    Australind , WA
    58
    1,256
    Quote Originally Posted by Sparksy View Post
    Yep, looks similar.
    I guess the BLDC uses hall effect sensors for timing from the controller?
    Probably rules out using a vsd, unless someone knows for sure?
  3. #18
    6,119
    Yep, looks similar.
    Hi Steve,
    A BLDC motor is fundamentally a three phase device and in theory could be run from a VSD. However it does use hall sensors to detect the position of the rotor with respect to the field coils. The hall sensor output is used to switch on or off the semiconductor devices used to pass power through the field coils at the right instant in time. Also by varying the time and duration of the power fed to the coils can be used to control the speed and the amount of output power the motor can produce.
    HTH.
  4. #19
    Sep 2006
    Australind , WA
    58
    1,256
    Hi Steve,
    HTH.
    Thanks John.....That helps alot.
    Maybe its worth buying a small VSD to test, as I have not come across anyone who definitvely knows for sure, either way.
    I have a copy of Roseneburg, but could not find anything in that.
  5. #20
    Sep 2006
    Australind , WA
    58
    1,256
    OOoooh, look. Looks like it will work, but its a bit of work. No Problem.
    https://www.youtube.com/watch?v=1oQPl-GqB0E
    I searched again, but using words , instead of abreviations this time and different results came up!
  6. #21
    6,119
    Steven, there is no point in trying to use a VSD to run that kind of motor ! As seen in the video he has direct access to all three motor phases. Without that, it would be a sure fire way of letting the smoke out.
    Its original controller would use a DC supply and the low resistance of the windings would need unknown amounts of current from that DC supply ! The supply voltage would only be switched on for a few fractions of a second for each phase of the motor windings, depending on speed and required power output. Also there may be multiple phases, more than the three you would normally expect.
    HTH.
  7. #22
    Sep 2006
    Australind , WA
    58
    1,256
    HTH.
    Noted John. Will do some more research.
    Its a last resort except for paying exorbitant money for a new Controller. Not worth it just for a shed.
    Will see.
  8. #23
    Apr 2020
    Hackham West
    54
    53
    Hope you get it sorted mate
  9. #24
    Sep 2006
    Australind , WA
    58
    1,256
    Quote Originally Posted by ericks2 View Post
    I might be flogging a dead horse yet.....lol...
  1. Controller WITHOUT a computer
    By nigelpearson in forum CNC Forum
    Last Post: 28th Feb 2022, 11:04 AM
  2. Replies: 5
    Last Post: 1st Dec 2019, 07:49 PM
  3. Mill motor controller !
    By BaronJ in forum METALWORK GENERAL
    Last Post: 14th Jul 2017, 01:51 AM
  4. Evap O Rust
    By Jim Ferrous in forum METALWORK GENERAL
    Last Post: 13th Oct 2013, 05:24 PM
  5. cheap foot TIG controller
    By WelderMick in forum WELDING
    Last Post: 17th Jan 2011, 01:33 PM
