Results 1 to 10 of 10
    Mar 2011
    Southern Flinders Ranges
    1,536
    Default How a VFD/VSD works
    Really good explanation of how a VFD/VSD works
    https://m.youtube.com/watch?v=yEPe7RDtkgo
    6,439
    Not a particularly good explanation ! To wordy and over done.
    7,182
    It's pretty difficult to explain VFDs without a lot of words, and any explanations with fewer words will usually leave a lot of gaps. I've had to do this many times, mostly at mens sheds when I visit them regarding dust extractor and inevitably end up attempting to explain how using a 3P with VFD impeller can be used to extract more air from a shed. It's easy to say. "higher frequency - higher speed" but explaining just how it does this gets into muddy waters fairly quickly. Some of the blokes don't really know what "frequency" means or have a very limited understanding of ordinary AC.
    In my VFDs4Newbies PDF I don't even bother to explain how they work. Instead I just focus on functional/limitation/installlation aspects
    Jun 2005
    Helensburgh
    618
    I agree with Bob, forget how it works and just use it. I use that method when we are doing dust extraction seminars in sheds and have never had anyone trying to question the how and the what when I explain the book is about 100 pages long.
    CHRIS
    7,182
    I've have had one person in an audience in about 10 years asks me how VFDs work. It turned out he already knew the answer and was just checking if I knew. I told him to come and see me about after the presentation and that's when he told me.
    Apr 2019
    Adelaide
    589
    I thought that was an excellent explanation.
    Given a 3 phase VFD has 3 groups of components (diodes, capacitor, IGBT) and a 1 phase only 2 groups (capacitor, IGBT) why are these things in such relatively big boxes?
    Mar 2011
    1,536
    Single phase input units also have a rectifier stage.
    Why is it so big, short answer is heat control.
    The individual power transistors represented in the video may in reality be made of several devices ganged together for current handling.
    If you pull one apart most of the the space is occupied by the power transistors, heat sink and fan.
    7,182
    Quote Originally Posted by Mk1_Oz View Post
    A small but not invaluable consideration is access.
    These are both 3HP VFDs the one on the left is a Powtran the other is an HY
    I just find it a lot easier to work on the one with the bigger terminals
    BTW the smaller Powtrans are just as cramped as the HYs.
    6,439
    There is a lot more to it than just three groups of components !
    Yes there are diodes and capacitors, there is also AC to DC to AC conversions along with frequency control. Think about how you get a three phase AC output from a single phase input. Plus all the control circuitry.
    I agree with Bob ! The KISS principle wins.
    Jul 2006
    Athelstone, SA 5076
    4,255
    Easier to just say:
    2 ways to vary speed of ac motor is to:
    Vary number of poles in motor, or
    Vary frequency to motor.
  1. HIMOUNT Lathe - $200 - not sure if it works or is complete
    By John T K in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 17th Jul 2018, 12:03 AM
  2. Thompsons works
    By morrisman in forum ANTIQUE AND VINTAGE MACHINERY
    Last Post: 6th Dec 2017, 09:23 AM
  3. B.S.A. Motorcycle Works - WWII
    By Ray-s in forum ANTIQUE AND VINTAGE MACHINERY
    Last Post: 11th Aug 2016, 11:57 PM
  4. Forge complete and works (mostly)
    By Bodgy in forum METALWORK GENERAL
    Last Post: 28th Mar 2006, 09:34 AM
