Results 1 to 7 of 7
26th Oct 2021, 07:04 PM #1Member
- May 2018
- Cairns, Qld.
- 70
Single phase to three phase motor replacement - Motor Size?
Gentlemen:- Regarding replacement of an existing single-phase electric motor with a VFD & three-phase unit, I recall reading on this forum that it may be a good idea to go up one size on the new motor; can any of the resident electrical gurus comment on the why & wherefore of this, please?
I'm considering changing the standard 2hp/1.5Kw drive motor on my AL-300 lathe in this way; thus possibly going up to a 2.2Kw rating on the 3 ph. replacement.
Regards,
Halifax
26th Oct 2021, 07:17 PM #2Member: Blue and white apron brigade
- 7,183
In this thread you will see a PDF "VFDs for Newbies" - read this for a detailed explanation - saves me reinventing the wheel.
https://www.woodworkforums.com/f271/vfds-newbies-232742
26th Oct 2021, 08:31 PM #3Most Valued Member
- Sep 2010
- Lebrina
- 1,910
I might well be wrong, but part of the answer will possibly relate to the reasons why you want to replace the single phase with 3 phase and a VFD. I'm guessing that if speed control is the reason or at least part of the reason for the change, then a larger motor could only be a good thing provided it fitted the given hole.
29th Oct 2021, 08:32 AM #4Most Valued Member
- 4,255
going up in hp/kw capacity may also result in motor frame size difference...meaning a new mount and pulley maybe required.
if you do go 3ph make sure the the VFD is suitable..ie is the motor going to be 3ph star or 3ph 240v delta. The VFD will need to match.
29th Oct 2021, 09:14 AM #5Member
- Nov 2016
- Gulfview Heights, Adelaide
- 83
Brand new motors can generally can be wired either star or delta, however you will need to check this before purchase.
Looking at my 4 pole motor chart, it is very likely you will go up a frame and shaft size. If so, you will need a larger pulley bore.
regards,
paul
8th Nov 2021, 07:54 AM #6Golden Member
- Jul 2011
- 837
12th Nov 2021, 07:01 PM #7Member
- May 2018
- Cairns, Qld.
- 70
Thank you gentlemen for all the replies.
H614
3 Phase Generator Motor Powered by Single Phase Motor?
By gazza2009au in forum ELECTRICALSReplies: 49Last Post: 4th Apr 2020, 04:38 PM -
Single phase Vs 3 phase motor ratings.
By KBs PensNmore in forum ELECTRICALSReplies: 56Last Post: 17th Sep 2017, 05:37 AM -
Replacing A Single Phase Motor With A Three Phase Motor....................
By matthew_g in forum METALWORK GENERALReplies: 26Last Post: 1st May 2015, 04:42 PM -
rewire 3 phase motor to single phase
By thorens in forum METALWORK GENERALReplies: 36Last Post: 5th Sep 2014, 07:16 PM -
Looking to swap a 2Hp single phase motor for 1.5 or 2Hp 3-phase motor
By jhovel in forum METALWORK GENERALReplies: 7Last Post: 10th Mar 2014, 07:26 PM
