Results 1 to 6 of 6
    Jul 2006
    Athelstone, SA 5076
    4,258
    Default Wood lsthe VFD conversion
    Picked up an the old 3ph woodfast lathe sometime back and its finally found some space in the shed.
    Fitted a vfd.
    What i like about this VFD is that it can convert hertz to theoretical RPM for the display with some simple programming of theoretical driven shaft rpm.
    Just need to fit perspex cover and black all the areas one doesnt want to see.eg wiring
    7,189
    The old wood fasts are nice bits of gear.
    What happens if you need to change the pulleys?
    Jul 2006
    Athelstone, SA 5076
    4,258
    Hoping I dont have to change speeds via pulley. At 110hz the spindle gets up to calculated 3619rpm.
    Inverter has sensorless vector so hoping it will have enough torque for turning at lower speeds.
    Any lower will only be for polishing anyways.
    But if I need to get more torque I change pulley ratio and adjust vfd to suit theoretical speed.
    Sep 2010
    Port Sorell, Tasmania
    74
    There's a general rule of thumb that says multiply the rpm by the diameter of the wood (in inches) and the result should be in the range of 6000 to 9000. If the wood is out of balance will have to start at a lower speed until it is evened up.
    You can work out your pulley ratios based on what you are likely to turn.
    Jul 2006
    Athelstone, SA 5076
    4,258
    Quote Originally Posted by tony_A View Post
    yep done all that.
    I have used 110mm drive/95mm driven pulleys so only need to go to 110hz to get the 3600rpm
    For more torque I could have gone 95mm drive/110driven but hz will be around 150...I have opted for lower hz but can change if needed.
    Sep 2010
    74
    yep done all that.
    I have used 110mm drive/95mm driven pulleys so only need to go to 11ohz to get the 3600rpm
    Looks like you've got it all sorted.
  1. DC motor conversion
    By errolf2 in forum THE HERCUS AREA
    Last Post: 14th Aug 2020, 09:05 PM
  2. Gear conversion
    Last Post: 9th May 2020, 09:58 PM
  3. AL-54B CNC Conversion
    By aussiejoeblow in forum METALWORK GENERAL
    Last Post: 22nd Jul 2011, 09:38 PM
  4. oxy lpg conversion
    By the fabricator in forum WELDING
    Last Post: 19th Sep 2010, 07:55 AM
  5. CNC conversion
    By sonic_racing in forum METALWORK GENERAL
    Last Post: 18th Jan 2009, 03:11 PM
