Results 1 to 5 of 5
    May 2020
    Willowbank QLD
    535
    Default Buffer bearing change
    Hello all
    Has anyone done a bearing change in a buffer like this?
    I removed the four bolts off the end cap and can see the bearing in the main housing.
    I removed the four bolts to remove the main housing and it does not want to move.
    Before I go applying a lot of force I thought I would ask for any tips from the experienced.
    6,473
    Hi Steve,
    Its no different from changing the bearing in a DE grinder !
    A little gentle persuasion with a mallet on the non CF switch end and the thing should come apart, watch out for any springs behind the bearings. Its usually the end bells that are tight, so a tap around the outside often helps.
    May 2020
    Willowbank QLD
    535
    Thanks, being 3 phase I don't think it should have a CF switch. Am I correct?
    6,473
    Quote Originally Posted by Reidy41 View Post
    Yes you are right !
    But from my viewing of the picture I can't tell whether it has a CFS or not .
    Either way dismantling it is no different. End bell caps are often very tight particularly if they have been painted over. The bearings are often tight on the shafts as well, which is where the mallet comes in handy splitting the end cap off.
    May 2020
    Willowbank QLD
    535
    Baron, thanks for your guidance. It is apart now. I had to resort to a FBH and block of wood.
  1. Calling all VFD experts for new Buffer
    By Reidy41 in forum ELECTRICALS
    Last Post: 28th Jul 2021, 10:25 PM
  2. Cast iron grinder/buffer stand - Sydney
    By WCD in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 31st Dec 2019, 11:14 PM
  3. cam bearing
    By morrisman in forum AUTO RESTORATION
    Last Post: 18th Oct 2019, 05:53 PM
  4. Bearing
    By WesP in forum METALWORK GENERAL
    Last Post: 25th Oct 2014, 12:16 PM
  5. Bearing Numbers
    By ljvs1951 in forum THE HERCUS AREA
    Last Post: 7th Sep 2009, 08:11 PM
