Results 1 to 5 of 5
Thread: Extension Lead Losses
8th Aug 2021, 11:15 PM #1Most Valued Member
A few years back I purchased a 10m 15amp lead to run from the generator to the panel.
Time to move the generator and while looking for a longer lead found my "extra heavy duty" lead is in fact 3 x 1.5mm.
I've purchased a 40m* 3 x 2.5mm lead to replace it, then I went looking for a loss calculator(ok maybe I got the order wrong there) to compare the two leads.
Well the calcs don't agree. So does this one pass a sanity check?
https://www.jcalc.net/voltage-drop-calculator-as3008
Vdrop 240V single phase 15A 2.5mm2 40m = 4.5% 10.81V
Vdrop 240V single phase 15A 1.5mm2 10m = 2.06% 4.95V
One of the other cals gives results around(but not exactly) half those......so fair to say I am missing something.
* will likely shorten this to around 20m at some stage. Which should make the losses ballpark the same as the 10m(I believe)
9th Aug 2021, 12:22 AM #2Senior Member
- Apr 2021
- 212
9th Aug 2021, 12:13 PM #3Senior Member
- Apr 2018
- 168
This page is from ASNZ 3001 shows max length for 10A and 15A leads in normal use and "high" current applications. (welders, motors etc). As you found out " extra heavy duty cables " dont have larger conductors just thicker outer sheathing.
9th Aug 2021, 11:14 PM #4Most Valued Member
Thank you.
I'm not sure its that easy.(but really if the above link is correct I'm not that worried.)
I should have included a link and numbers
Vdrop 240V single phase 15A 2.5mm2 40m = 1.75% 4.2V (so less than 50%)
Vdrop 240V single phase 15A 1.5mm2 10m = 1.21% 2.91V(more than 50%
https://www.rapidtables.com/calc/wire/voltage-drop-calculator.html
I figured if it was just a "double length" issue it would at least be the same error(which I didn't exactly make clear in my OP)
Thank you Sparky I will have to keep that handy.
Now I just need a clever way of knowing when the mains come back on.
9th Aug 2021, 11:53 PM #5Senior Member
- Apr 2021
- 212
I think the numbers are close enough to suggest that it is that simple. I don't know where your data comes from but resistance is also a function of temperature and it might be that the on-line calculator used a different temperature. Other than the "double length" issue, there is little else that would cause a difference that is very close to a factor of two.
Even with the small discrepancy, I trust your issue is resolved.
Jack
Welding off an extension lead (or five)
By RustyArc in forum WELDINGReplies: 6Last Post: 13th Aug 2017, 11:53 PM -
Bandsaw Extension Table
By Oldneweng in forum METALWORK PROJECTSReplies: 10Last Post: 6th Jan 2016, 01:56 PM -
Drawbar extension
By SurfinNev in forum TRAILERS & OTHER FABRICATED STUFFReplies: 13Last Post: 23rd May 2012, 11:37 AM -
eBay wins and losses.
By Ropetangler in forum METALWORK GENERALReplies: 7Last Post: 28th Jul 2010, 12:32 AM
