Results 1 to 8 of 8
Thread: change over switch
30th Jul 2021, 10:40 AM #1Most Valued Member
- Healesville
- 2,129
change over switch
G/day falla's, i have a couple of these automatic change over switches that i want to utilise for backup power to my house.
The basic instructions make no mention about the input/outputs on the top of the change over switches and i have done goog searches with no success,
it would be nice if i could know what functions that i could utilise with these.
Has anyone had experience with these and maybe a ciruit diagram, or maybe even decode the terminal lable for me into info that i might be able to utilise.
Cheers shed
30th Jul 2021, 12:14 PM #2
Does this help ?
https://www.ato.com/Content/doc/63A-...ser-manual.pdf
30th Jul 2021, 12:42 PM #3Most Valued Member
- Healesville
- 2,129
30th Jul 2021, 05:05 PM #4
Look, I have no idea of your background or expertise but if this section in the manual I posted does not answer your question then respectfully you need to call an electrician as it has ALL the detail.
30th Jul 2021, 05:50 PM #5Most Valued Member
- Healesville
- 2,129
droog i understand how to connect the power wires, that is not my problem, i am wanting info regarding the control inputs/outputs numbered 1 - 6 in the first picture in the first post. Maybe reread my first post, i thought it was understandable?
30th Jul 2021, 06:17 PM #6
30th Jul 2021, 06:53 PM #7
So after a bit more Googling it appears that the connections on top are for status indicator lights only. The note " when the switch is level 3, please connect the zero line to the 3 and 6 connectors" falls inline with the 3 pole version where no neutral is present on the device.
A quick check with a continuity tester should confirm it.
I do not believe any control features are available via this connector.
30th Jul 2021, 10:09 PM #8Most Valued Member
- Healesville
- 2,129
ok thanks droog, i just looked up that symbol, i spoze an indicator light will be handy.
"A light bulb is shown as a circle with a cross inside it. It produces light when a current is passed through it."
FOBCO Switch.
By BaronJ in forum METALWORK GENERALReplies: 4Last Post: 12th Apr 2018, 12:57 AM -
Replacing a Switch.
By wm460 in forum METALWORK GENERALReplies: 9Last Post: 30th Apr 2017, 10:49 PM -
Switch Enclosure- Switch Position Identification.
By Anorak Bob in forum METALWORK GENERALReplies: 17Last Post: 19th Jul 2016, 11:00 AM -
Switch wiring
By DSEL74 in forum METALWORK GENERALReplies: 13Last Post: 3rd Jun 2015, 07:02 PM -
Need switch
By nadroj in forum METALWORK GENERALReplies: 1Last Post: 4th Nov 2009, 09:31 AM
