Results 1 to 6 of 6
    Oct 2011
    Sydney, NSW
    1,249
    Default New Switch for Bandsaw
    Good Morning All,
    I've bought a new switch for my bandsaw. Before I wire it up I want to confirm I can put the earths to the frame of base of the bandsaw (instead of to the metal frame of the original switch - photo drill press 3 shows the earthing). I've attached a few photo's that will hopefully clear up what I'm saying.
    Ben.
    Dec 2020
    Geraldton Western Australia
    132
    1.Is the new switch all plastic? 2. Does it have any provision for an earth screw?
    If 1. is yes and 2. is no , then you can earth to the bandsaw metal frame, making sure that it is directly on the steel frame, NO Paint, bare metal only.
    Cam.
    Oct 2011
    Sydney, NSW
    1,249
    Hi,
    Yep the new switch is all plastic and doesn't have anywhere for the earth wires.
    Cheers.
    May 2021
    Sunshine Coast QLD
    62
    Looks like you will end up with the short piece of “Earth” wire left over. (The bit that currently runs from the switch to the frame.)
    Is that your understanding?
    I was slightly horrified when I went to shorten up the cable on a second hand thicknesser I’ve just bought. (Woodworking - sorry)
    Upon opening it up - the earth was simply left unconnected.
    6,444
    Hi Skypig, Guys,
    My Chinese BF20LB Optimum clone was like that, the incoming earth wire just floating in mid air. The earth bolt was there, just nothing connected to it. Motto do an earth continuity check before powering up !
    Jul 2010
    9,088
    Quote Originally Posted by skypig View Post
    Two of the machines I've opened weren't that rough, the earth had to be connected as otherwise they wouldn't have been able to use it a neutral (3 phase machines with 240V controls so needed a 5 pin plug/socket which I guess was't available.)
  1. Bandsaw questions- and identify my old bandsaw?
    By Pete O in forum METALWORK GENERAL
    Last Post: 23rd Apr 2020, 12:14 AM
  2. Replacing a Switch.
    Last Post: 30th Apr 2017, 10:49 PM
  3. Switch Enclosure- Switch Position Identification.
    Last Post: 19th Jul 2016, 11:00 AM
  4. Undervoltage switch
    By nearnexus in forum METALWORK GENERAL
    Last Post: 8th Aug 2013, 12:21 AM
  5. Need switch
    By nadroj in forum METALWORK GENERAL
    Last Post: 4th Nov 2009, 09:31 AM
