Results 31 to 45 of 54
Thread: Test & Tag Machine Calibration
17th May 2021, 05:19 PM #31
Hi Karl, Guys,
except he tagged several power tools that did not work as being a pass
I've had it stated that plugs should be cut off to prevent a failed power tool from being put back into service.
The argument there is that another plug can easily be fitted. Then the argument is made that the plug should be moulded on making the assumption that new refittable plugs are not available.Best Regards:
17th May 2021, 06:55 PM #32Most Valued Member
17th May 2021, 07:01 PM #33Most Valued Member
17th May 2021, 09:18 PM #34
The same applies if I was selling a used electrical item as "Untested", otherwise it is supposed to be tested and tagged as failed.Best Regards:
17th May 2021, 10:32 PM #35Most Valued Member
Whether you cut the plug or the cord off you are still damaging someone else’s property. I don’t know what the rules are in the UK, but in Oz AS3760 dictates how testing and tagging is to be carried out. Clause 2.4.1 says the tester must tag non-compliant equipment as unserviceable and it must be withdrawn from service. Nothing about rendering it unusable.
18th May 2021, 12:29 AM #36Senior Member
- Oct 2015
- melbourne
- 473
T&t isn't supposed to confirm the item is functional, only that it is electrically safe.
Would you rely on a 'competent' tester to confirm that your drill/lathe/tv/computer/power supply is functioning correctly? Cutting off the plug just makes it that much harder to repair if it is faulty anyway.
Russ
18th May 2021, 06:44 AM #37
Hi Guys, thank you for your posts !
I can see and understand the points that you make. I don't disagree ! It enhances my understanding, It seems that the rules vary for different environments.
Whilst having done a T&T course, from within a retail environment, it doesn't make me any more qualified or experienced than I was previously. I was never employed as a tester anyway ! It just happened that I got put on the course at the time.
I personally didn't get any form of accreditation from going on this course, non I remember anyway. I still think that is a bandwagon jumped on as a money maker.Best Regards:
18th May 2021, 07:33 AM #38Most Valued Member
18th May 2021, 03:37 PM #39Member: Blue and white apron brigade
- 7,183
We are in the middle of a minor bathroom reno - well, . . . . . full strip out and new for old replacements.
My shins are still suffering from multiple bites from tile chips from removing the tiles -= shoulda worn long daks.
Anyway this is an "extension" of one of the tiler's angle grinder cords.
BTW he is a top tiler - probably the best we've ever had
18th May 2021, 06:07 PM #40Pink 10EE owner
- 6,216
Where is the problem. It has a tag on it so none of us are qualified to determine anything.
19th May 2021, 11:03 AM #41Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,536
You asked for recommendations based on an unsatisfactory experience at a cheaper facility, now it’s too expensive to take it somewhere reputable. I look at it this way, if I were to be standing in front of the coroner or a work safe investigator, would I want to be explaining my decision making? In the greater scheme of things, $400 to verify your test equipment, even for a smaller company, is not a particularly onerous sum of money, particularly when you have doubt over your equipment as it stands.
Cutting the plug off creates a bigger hazard as it creates a potential touch point at the back of the plug should someone put the plug into an outlet (yes, they walk amongst us).
Yes it has spawned an industry in its own right, but that is to stop no eff’s given contractors turning up on job sites with stuff that’s unfit for use. If people could be trusted to do the right thing and not put production before safety then there would be no need for regulation.
19th May 2021, 11:54 AM #42Most Valued Member
“Your Honour, there is no requirement in AS3760 to have a PAT tester checked”
I see where you are coming from, but my boss pays the bills and she is also the Responsible Person under the WHS Act. She told me if it’s not a requirement then don’t bother. Works for me.Chris
19th May 2021, 12:23 PM #43Most Valued Member
- Mar 2011
- 1,536
That does make the decision making process somewhat easier
19th May 2021, 01:20 PM #44Most Valued Member
Sure does!
19th May 2021, 03:29 PM #45Pink 10EE owner
- 6,216
Nope, you forget bureaucracy is an industry and like any other industry it likes to grow bigger. Like I explained before. The people in the regulatory industry having got the big issues sorted go down the list to the absurd. It is no skin of the nose of the regulators as they do not have to concern themselves with any bankruptcies, mayhem or suicides they create as they are not in the industries they are regulating.
You will notice that things that the vast majority do are lacking in regulatory requirements compared to other things. A drivers licence is an absolute classic example. Thousands killed every year, tens upon tens of thousands seriously injured, yet look at the regulatory requirement compared to what other industries have to comply with. Once you have a drivers licence, you never need re-accreditation.Gold, the colour of choice for the discerning person.
Check calibration of a hall effect led rpm indicator?
By Halifax614 in forum ELECTRICALSReplies: 18Last Post: 2nd Dec 2020, 08:37 PM -
Maths help re levels and calibration
By bollie7 in forum METALWORK GENERALReplies: 18Last Post: 30th Apr 2020, 09:04 PM -
Micrometer calibration gauge block sets
By elanjacobs in forum METALWORK - Machinery, Equipment, MARKETReplies: 0Last Post: 18th Nov 2019, 10:59 PM -
Surface Plate Calibration Video
By Oldneweng in forum METALWORK GENERALReplies: 5Last Post: 3rd Feb 2016, 04:00 PM -
Machine Tool Test Cerificates
By simonl in forum METALWORK GENERALReplies: 16Last Post: 28th Jul 2014, 05:53 PM
