Page 1 of 2 12 LastLast
Results 1 to 15 of 24
Thread: winch motor
    Apr 2012
    Healesville
    2,129
    Default winch motor
    Hi fella's, free running (no load) this little 12v ATV winch motor pulls 17.5 amps in working/load direction and 12 amps in the feed the cable out direction?
    The brushes are 90 deg apart and there is no brake.
    I want to run it in the reverse direction to take advantage of the lower amperage as I only have 30 amps at the plug on the back of my car, also I am using a 2:1 pulley reduction for the cable so it will be only lifting under 100kgs.
    It has an epicyclic gear box, all spur gears so no probs there.
    Why the amps are differant from 1 direction to the other has me confused and I am wondering if the low amp direction might be less efficient and actually pull more amps under load than the other direction?
    Has anyone got any clues about this?
    Nov 2010
    Frankston south
    102
    What happens when you reverse the polarity? Could be a timing issue.
    Apr 2012
    Healesville
    2,129
    Quote Originally Posted by waxen View Post
    G/day waxen, that is how the motor is reversed.
    Nov 2016
    Gulfview Heights, Adelaide
    83
    Have you measured the motor current under load? It may be less than 30 amps in either direction.
    Dec 2018
    NSW
    586
    Load (Amps) increases as motor is under load (mechanical). Up until the point it stalls and draws many, many amps, and melts cables/blows fuses.
    Irrespective of the way it's wired, your circuit (cabling / fuse) would need to cater for more than what you observe under no load. I believe you can calculate stall load based off motor HP (as a general guide only).
    Your mileage may vary, but I'd consider wiring to at least 16mm^2 cable for power and earth side, and adjust cable size UP accordingly for voltage drop based off distance from the power source (battery). Any connection would need to cater for the Amp draw you are expecting. You may be able to spec-down such connections, but keep in mind that will then be your weak-link in the circuit, and your duty cycle/trigger finger will need to be adjusted accordingly.
    Oct 2007
    Alexandra Vic
    69
    654
    It is quite common for brushed DC motors to have the timing advanced for the nominal direction of rotation that the motor is expected to run in. This increases the torque available and the power that can be consumed. I believe that this is the case in your situation. If you were to attempt to operate the unit in the reverse direction while under a pulling load, it would be less efficient and draw more current than it would pulling the same load in the nominal pulling direction. i.e, operating the motor under load in reverse direction draws more than the same load in the normal direction would.
    A potential solution would be to invest in a V8 or diesel capable jump starter and power the winch from that, or install an extra battery and charge controller in the boot to avoid needing to pull a lot of current through the existing cabling.
    Dec 2018
    NSW
    586
    Reading again, might add the following:
    The device that is a load in the circuit draws the current - Amps are not 'available' to use, they are drawn by the device requiring power.
    While the device free-spools at a low amp draw, this changes when mechanical load on the motor is applied. Having a gearbox (torque multiplier) minimizes the load the motor 'sees'.
    Now I'm not 100% up to speed with how the brush orientation, air gap, and magnetic field affect torque, but I am led to believe this has something to do with it
    Apr 2012
    Healesville
    2,129
    Quote Originally Posted by paul33 View Post
    No Paul, still in makin' it stage...
    Apr 2012
    Healesville
    2,129
    Quote Originally Posted by malb View Post
    It is quite common for brushed DC motors to have the timing advanced for the nominal direction of rotation that the motor is expected to run in. This increases the torque available and the power that can be consumed. I believe that this is the case in your situation. If you were to attempt to operate the unit in the reverse direction while under a pulling load, it would be less efficient and draw more current than it would pulling the same load in the nominal pulling direction. i.e, operating the motor under load in reverse direction draws more than the same load in the normal direction would..
    Timing.....thanks Mal
    Apr 2012
    Healesville
    2,129
    Default ok some clarification
    The spec's for the winch are from what I can ascertain...
    12 volt 1 or 1.2 kw motor
    Gear ratio 153:1
    Load rating 3000 pounds = 1360kgs
    1200w / 12v = 100amps
    As I only have 30amps at the back of the car I am trying to make this winch operate at less than 30 amps as I don't want to have to upgrade the wiring unless I have to.
    So where I am at is I have fitted a cable/pulley reduction of 2:1, so now the motor thinks it has a 306:1 gearbox to make its life a bit easier.
    My dodgy estimated calcs,
    full load of 1360kgs pulls 100amps from the motor
    1360kg / 100kg = 13.6 (lifting load)
    100amps / 13.6 = 7.35amps
    No load amps + dodgy calculated amps 17.5 + 7.35 = 24.85 amps .......
    Time will tell
    6,473
    Hi John,
    The motor current draw when spooling out will always be less than the current when pulling a load ! You can't change that !
    I my opinion you have gone in the right direction by increasing the gear ratio. A two to one reduction should reduce the motor loading by the same amount, however you might find that the motor current draw doesn't reduce in the same ratio.
    A secondary battery and short heavy cables will help tremendously. I would take pains to actually measure the current draw of the motor under the actual load that you want it to move. A temporary fully charged battery and heavy cables using a clamp amp will assist in getting the parameters right.
    Bear also in mind that you will have to charge a secondary battery and keep it charged otherwise you may find that the vehicle wiring cannot cope with the motor load. So you will need to provide suitable fusing to the secondary battery.
    HTH.
    Apr 2012
    Healesville
    2,129
    Sure, I would be surprised if my mangled math was even close.
    I still have a fair bit of work to do yet but yep I will check it before I plug it into the car
    6,473
    Sure, I would be surprised if my mangled maths was even close.
    Your maths is probably better than mine
    The motor load going down by a half but the motor current might only go down by a third at any given load.
    Oct 2009
    Upwey VIC
    187
    [QUOTE=shedhappens;1980424
    Has anyone got any clues about this?[/QUOTE]
    A secondary gearbox with a built-in 2:1 reduction and tumbler reverse between the drum and the epicyclic gearbox output would do the job.
  15. #15
    Apr 2012
    Healesville
    2,129
    Quote Originally Posted by mahgnia View Post
    I will update my wheelchair thread in the project section so that you can see the mischief that i am getting up too
  1. 3 Phase Generator Motor Powered by Single Phase Motor?
    By gazza2009au in forum ELECTRICALS
    Last Post: 4th Apr 2020, 04:38 PM
  2. Three phase motor electric motor
    By china eyes in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 5th Dec 2018, 04:02 AM
  3. Winch post angle
    By mbaldwin in forum TRAILERS & OTHER FABRICATED STUFF
    Last Post: 6th Aug 2016, 11:57 AM
  4. Replies: 26
    Last Post: 14th Aug 2015, 02:38 PM
  5. Replies: 7
    Last Post: 10th Mar 2014, 07:26 PM
